Challenger power steering high pressure hose #902025
01/11/11 01:48 PM
01/11/11 01:48 PM
Switzerland, Europe
Swiss_Robert Offline OP
Switzerland, Europe
My 1970 Challenger 440 SixPack is unfortunately a careless made clone. As longer as I work on it as more parts I find that are not correct for that car.
Now I'm dealing with the high pressure hose of the power steering. Regarding Year One there were different hoses for small block and big block engines - and my big block had one built in that was intendet for a small block (see pic of mine).
So IF IT WOULD FIT, this would be an occasion to change it against a correct one ( see here it's the same like A-Body) which is about 2" longer and has different metal pipes but the same fittings.
Well, I GUESS it would fit....
Any comments?
After all these years having a 440 I realized that this means having an attitude... and a budget.
Re: Challenger power steering high pressure hose [Re: Swiss_Robert] #902026
01/11/11 03:57 PM
01/11/11 03:57 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
What P/S pump did they put on it?
Re: Challenger power steering high pressure hose [Re: FJ5_Fish] #902027
01/11/11 06:32 PM
01/11/11 06:32 PM
Switzerland, Europe
Switzerland, Europe
A .94 / Saginaw, the one with the oval filler neck.
Re: Challenger power steering high pressure hose [Re: Swiss_Robert] #902028
01/11/11 06:37 PM
01/11/11 06:37 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
Original power steering hoses are very easy to find...
http://cgi.ebay.com/ebaymotors/NOS-Mopar...sQ5fAccessories
There's no need to buy the Year One aftermarket crap.
CHECK OUT MY NEW WEB SITE !
Re: Challenger power steering high pressure hose [Re: anlauto] #902029
01/11/11 06:41 PM
01/11/11 06:41 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
get me engine and power steering pump information , I'll get you a part number.
Then you might be able to get it locally. Although shopping for old muscle car parts in Europe might be a bit of a challenge, but I can assure you there are multiple sources for hoses besides Yearone
Re: Challenger power steering high pressure hose [Re: gtx6970] #902030
01/11/11 06:49 PM
01/11/11 06:49 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Bill - it's a 440 with a Saginaw pump
Re: Challenger power steering high pressure hose [Re: Morty426] #902031
01/11/11 07:00 PM
01/11/11 07:00 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Well - At least they put the right pump on it.
Re: Challenger power steering high pressure hose [Re: Swiss_Robert] #902032
01/11/11 07:13 PM
01/11/11 07:13 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
The most popular pressure hose supplier is Omega and there part number is 546 or maybe ome546, Retail on it is right at $38
this crosses to an AC delco # as well just in case
pt # 36-352830
I can get it locally but it needs to be special ordered
Re: Challenger power steering high pressure hose [Re: gtx6970] #902033
01/11/11 07:21 PM
01/11/11 07:21 PM
Switzerland, Europe
Switzerland, Europe
"A bit of a challenge" - to get parts for a Challenger???
Seriously: Easiest is to shop that stuff over there at you - in USA. Even with freight charges it's cheaper and hundred times less frustrating.
For me Yearone is a good source - they have a lot of things at "one stop" - and it's not all crap. Sometimes it's costly - and sometimes it's poor quality but it's calculably. I never had to dispose anything from them. And their helpdesk isn't too bad. So it's a way... even if some of you obviously don't really like them.
Re: Challenger power steering high pressure hose [Re: gtx6970] #902034
01/11/11 07:26 PM
01/11/11 07:26 PM
Switzerland, Europe
Switzerland, Europe
pt # 36-352830
That one?
