My 1970 Challenger 440 SixPack is unfortunately a careless made clone. As longer as I work on it as more parts I find that are not correct for that car.
Now I'm dealing with the high pressure hose of the power steering. Regarding Year One there were different hoses for small block and big block engines - and my big block had one built in that was intendet for a small block (see pic of mine).
So IF IT WOULD FIT, this would be an occasion to change it against a correct one (
see here it's the same like A-Body) which is about 2" longer and has different metal pipes but the same fittings.
Well, I GUESS it would fit....
Any comments?
