70 charger ground #901986
01/11/11 01:14 PM
01/11/11 01:14 PM
louisiana
mopar70charger Offline OP
louisiana
is there any ground wire or anything for the automatic transmission 727 with 400 big block..
Re: 70 charger ground [Re: mopar70charger] #901987
01/11/11 01:34 PM
01/11/11 01:34 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I'm not positive, but I believe it grounds through one of the top engine/ trans bolts to the firewall.
Re: 70 charger ground [Re: jbc426] #901988
01/11/11 01:52 PM
01/11/11 01:52 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
No ground wire. The trans is grounded by being bolted to the motor and linkage etc.
Re: 70 charger ground [Re: stumpy] #901989
01/11/11 06:14 PM
01/11/11 06:14 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
Well, none of it is "grounded" unless it's actually hooked to something.
Basically, a front mount battery needs to be grounded to the engine, which handles the heavy starter current.
The regulator, mounted on the body, as well as accessories such as lights and heater, need to be grounded to the battery neg. So there needs to be AT LEAST one big jumper from the engine to the body, or from the battery neg. to the body.
If the battery is in the trunk, the battery will be grounded to the body. A nice big jumper needs to be from the engine to the body
Re: 70 charger ground [Re: mopar70charger] #901990
01/11/11 06:35 PM
01/11/11 06:35 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Beginning in 1970, the only ground 'wire' is the one off the negative battery cable to the radiator support and then the primary ground lead for the engine and trans is the neg bat cable to the engine
Re: 70 charger ground [Re: mopar70charger] #901991
01/11/11 06:59 PM
01/11/11 06:59 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
well since the 400 wasn't in a 70 Charger I'm guessing your trans might be off the 400? maybe some late modle 400 cars had somekind of ground. A 70 charger does not have any wires coming off the trans except the N/S switch.
Coming soon!!!!
Re: 70 charger ground [Re: Mr.Yuck] #901992
01/11/11 08:19 PM
01/11/11 08:19 PM
louisiana
louisiana
thanks to all and to mr. yuck..how's your motor coming..
Re: 70 charger ground [Re: mopar70charger] #901993
01/11/11 09:18 PM
01/11/11 09:18 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
done and in, just have to get the new fuel system in. can you take a picture of the wire?
