factory finish on motor mount hardware #901373
01/10/11 06:27 PM
01/10/11 06:27 PM
PA
BTTG Offline OP
BTTG  Offline OP
PA
What is the correct factory finish on the nuts/bolts used to attach the motor to the K member through the engine mounts?
Thought it was black phosphate, but have seem some that appear to be zinc.
If it makes a difference talking about BB 1969.
Re: factory finish on motor mount hardware [Re: BTTG] #901374
01/10/11 07:20 PM
01/10/11 07:20 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
FWIW, The bolts that go through the motor mounts and K-frame that came out of my Oct. 1969 build 1970 318 Challenger had a sliver finish and were not black phosphate.
Joe
65 Barracuda
70 Challenger
Re: factory finish on motor mount hardware [Re: BTTG] #901375
01/10/11 07:32 PM
01/10/11 07:32 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
The Long "38" bolts are silver cad. The nuts can vary from silver cad or zinc phosohate. The washers are usually silver cad or silver zinc.
Not much on a Mopar is black phos.
Here is the original hardware on a 69 440. The silver cad has worn off of the treads on the short bolts but is still clearly evident on the head. Every car that Chrysler made had motor mount hardware (100's of thousands of bolts) so you can expect some vendor variance here and there.....I am just reporting what I have seen for years and what is on my original stuff.
Re: factory finish on motor mount hardware [Re: FJ5_Fish] #901376
01/10/11 07:53 PM
01/10/11 07:53 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Actually, I thought someone put together a good list of finishes that was posted a while back. If a link isn't posted shortly I will ask in a separate post.
Re: factory finish on motor mount hardware [Re: BTTG] #901377
01/10/11 09:27 PM
01/10/11 09:27 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
I also need this info for my 70 Charger...I assume 69-70 will be the same.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: factory finish on motor mount hardware [Re: 70gtx440dana] #901378
01/10/11 09:30 PM
01/10/11 09:30 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
70 is the same as the 69 pic I posted.
Re: factory finish on motor mount hardware [Re: FJ5_Fish] #901379
01/14/11 03:27 PM
01/14/11 03:27 PM
South Florida
goalsetterpk Offline
South Florida
Thanks for your pic, dumb question is that the correct way to orient the multiple bolts that attach to the motor block? I've seen them different ways not sure if that was mother mopar or not?
Re: factory finish on motor mount hardware [Re: goalsetterpk] #901380
01/14/11 05:52 PM
01/14/11 05:52 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
The FSM (factory service manual) and the engineering show the proper way to install the bolts, nuts and washers......hopefully I did it right in that photo.....
Re: factory finish on motor mount hardware [Re: FJ5_Fish] #901381
01/14/11 05:59 PM
01/14/11 05:59 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
IIRC there is only 1 washer per bolt/nut combo and I would say it goes alongside each nut.
