deck clearance
#900471
01/09/11 08:02 PM
01/09/11 08:02 PM
Posts: 553 Kentucky
clovis
Kentucky
what is the most variation in deck clearance cylinder to cylinder you have run? At what point does it create an issue?
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: deck clearance
[Re: Cab_Burge]
#900474
01/09/11 09:17 PM
01/09/11 09:17 PM
Posts: 553 Kentucky
clovis
Kentucky
I have a slight angle front to back on the block at about .003-.004, same on both sides. It looks to move .001 per hole. I have about .008 variation in the rods (a couple have been resized). So by matching rods to cylinders I can vary from .008-.013 in the hole, which puts the quench at .035-.040 with a .027 gasket. I can true up the rods to the shortest length, go .013-.016 in the hole and have quench at .040-.043 with the same .027 gasket. Then again, I can true up the deck and rods, put them .005 in the hole and use a .040 gasket.
I just want to spend where I need to, too many other things that need attention and money.
Re: deck clearance
[Re: clovis]
#900475
01/10/11 01:36 AM
01/10/11 01:36 AM
Posts: 43,180 Bend,OR USA
Cab_Burge
It's your choice Lots of ways to skin the kitty to get good results
