Any Rhoads lifters users? And do they help ET? #900388
01/09/11 04:49 PM
01/09/11 04:49 PM
S.W. PA
6PACMAC Offline OP
6PACMAC  Offline OP
S.W. PA
Anybody use them and how did they work out in helping your ET? Also, did they clean up your idle quality ?
Re: Any Rhoads lifters users? And do they help ET? [Re: 6PACMAC] #900389
01/09/11 08:03 PM
01/09/11 08:03 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
They work very well on the older slower ramps like the MP Purple shafts, I've found they helped the off idle response and maybe a little uppeer bottom torque, especially on shorter stroke motors like 340's and 383's.
I don't think I'd want to try them on the modern fast ramps like the Bullet/;ater U'Ds or the Comp XE's
For ET, probably not, I ran nearly all 4 speed stuff back in the days (late 70's early-mid 80's so I was normally dumping the clutch at a higher RPM than any of the bleed down would have effected.
That said they'ed be most beneficial in apps where the converter was borderline tight for the cam or if the combo was slightly under-geared.
WIZE
In Car:
Re: Any Rhoads lifters users? And do they help ET? [Re: Streetwize] #900390
01/10/11 12:54 AM
01/10/11 12:54 AM
S.W. PA
6PACMAC Offline OP
6PACMAC  Offline OP
S.W. PA
Re: Any Rhoads lifters users? And do they help ET? [Re: 6PACMAC] #900391
01/10/11 10:11 PM
01/10/11 10:11 PM
S.W. PA
6PACMAC Offline OP
6PACMAC  Offline OP
S.W. PA
Re: Any Rhoads lifters users? And do they help ET? [Re: 6PACMAC] #900392
01/10/11 10:42 PM
01/10/11 10:42 PM
detroit area
moderncylinder Offline
detroit area
i used them before,,, long time ago,,,,, never,, ever,, ever,, ever again.......
Re: Any Rhoads lifters users? And do they help ET? [Re: moderncylinder] #900393
01/10/11 10:58 PM
01/10/11 10:58 PM
owt west
Thread Ender1 Offline
owt west
Gimmick! good for a GM smogger with a lumpy cam and power brakes thats about it. You need adjustable rocker arms too.
Re: Any Rhoads lifters users? And do they help ET? [Re: moderncylinder] #900394
01/10/11 11:11 PM
01/10/11 11:11 PM
Manistee, Michigan.
High Impact Offline
High Impact  Offline
Manistee, Michigan.
I bought a set to tame down my old 284/484 Purple cam thats in my 383 69 Superbee. It does idle alittle better but it depends on what weight oil im running too. 20-50 seems to run better than 10-30??
The other thing it helped on was vacuum at an idle, I gained 2in.
All I can say is they worked for my engine combo. I hate that camshaft with how rough it runs but the lifters made it live-able till I install a diffrent cam.
Re: Any Rhoads lifters users? And do they help ET? [Re: moderncylinder] #900395
01/11/11 12:05 AM
01/11/11 12:05 AM
S.W. PA
6PACMAC Offline OP
6PACMAC  Offline OP
S.W. PA
Why the never, ever? Whats up with'em? Heres why I'm thinking of giving them a shot. For a little cleaner idle in the staging lanes. The cam is 270ish at .050, 320 at .003. Lift is .533. The heads are non ported 906s, for IHRA crate motor setup.
Re: Any Rhoads lifters users? And do they help ET? [Re: High Impact] #900396
01/11/11 12:43 AM
01/11/11 12:43 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The other thing it helped I gained 2in.
Wow... that sounds great! Good for you!
Re: Any Rhoads lifters users? And do they help ET? [Re: Kern Dog] #900397
01/11/11 12:50 AM
01/11/11 12:50 AM
USA
JoesMopar Offline
JoesMopar  Offline
USA
Sounds more like a Viagra statement...
Re: Any Rhoads lifters users? And do they help ET? [Re: 6PACMAC] #900398
01/11/11 01:33 AM
01/11/11 01:33 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I have a set in a Ford 302 with an older style cam and they do what they claim. This motor idles and pulls down low much better than it should for the cam thats in it. They are noisey, sound like solid lifters that need adjusting after the oil warms up.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Any Rhoads lifters users? And do they help ET? [Re: HemiRick] #900399
01/11/11 05:13 PM
01/11/11 05:13 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Ditto, except I had a 440 that I ran them in.
