Re: Any Rhoads lifters users? And do they help ET?
[Re: 6PACMAC]
#900389
01/09/11 08:03 PM
01/09/11 08:03 PM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
They work very well on the older slower ramps like the MP Purple shafts, I've found they helped the off idle response and maybe a little uppeer bottom torque, especially on shorter stroke motors like 340's and 383's. I don't think I'd want to try them on the modern fast ramps like the Bullet/;ater U'Ds or the Comp XE's For ET, probably not, I ran nearly all 4 speed stuff back in the days (late 70's early-mid 80's so I was normally dumping the clutch at a higher RPM than any of the bleed down would have effected. That said they'ed be most beneficial in apps where the converter was borderline tight for the cam or if the combo was slightly under-geared.
[Re: Streetwize]
#900390
01/10/11 12:54 AM
01/10/11 12:54 AM
Posts: 915 S.W. PA
6PACMAC
S.W. PA
[Re: 6PACMAC]
#900391
01/10/11 10:11 PM
01/10/11 10:11 PM
Posts: 915 S.W. PA
6PACMAC
S.W. PA
[Re: 6PACMAC]
#900392
01/10/11 10:42 PM
01/10/11 10:42 PM
Posts: 1,752 detroit area
moderncylinder
detroit area
i used them before,,, long time ago,,,,, never,, ever,, ever,, ever again.......
[Re: moderncylinder]
#900393
01/10/11 10:58 PM
01/10/11 10:58 PM
Posts: 2,679 owt west
Thread Ender1
owt west
Gimmick! good for a GM smogger with a lumpy cam and power brakes thats about it. You need adjustable rocker arms too.
#900395
01/11/11 12:05 AM
01/11/11 12:05 AM
Posts: 915 S.W. PA
6PACMAC
S.W. PA
Why the never, ever? Whats up with'em? Heres why I'm thinking of giving them a shot. For a little cleaner idle in the staging lanes. The cam is 270ish at .050, 320 at .003. Lift is .533. The heads are non ported 906s, for IHRA crate motor setup.
[Re: High Impact]
#900396
01/11/11 12:43 AM
01/11/11 12:43 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
The other thing it helped I gained 2in.
Wow... that sounds great! Good for you!
[Re: Kern Dog]
#900397
01/11/11 12:50 AM
01/11/11 12:50 AM
Posts: 2,782 USA
JoesMopar
USA
Sounds more like a Viagra statement...
[Re: 6PACMAC]
#900398
01/11/11 01:33 AM
01/11/11 01:33 AM
Posts: 4,848 Memphis
HemiRick
Memphis
I have a set in a Ford 302 with an older style cam and they do what they claim. This motor idles and pulls down low much better than it should for the cam thats in it. They are noisey, sound like solid lifters that need adjusting after the oil warms up.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: HemiRick]
#900399
01/11/11 05:13 PM
01/11/11 05:13 PM
Posts: 10,218 Someplace you aren't
SomeCarGuy
Ditto, except I had a 440 that I ran them in.
