Horsepower TV 360 budget build show?
#900355
01/09/11 04:42 PM
01/09/11 04:42 PM
Posts: 1,263 Southwestern Ontario Canada
racealittle
Anyone see the new episode this weekend?
Apparently bought a hurt motor with very good parts for something like $450.
Looks like a magnum block and crank with LA eddy heads. roller cam, etc.
How do you get LA heads to oil properly with a magnum block?
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: Horsepower TV 360 budget build show?
[Re: racealittle]
#900357
01/09/11 04:48 PM
01/09/11 04:48 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
I laughed when they drained the pan and said all the water that gushed out was condensation.What a bunch of rubes.Whoever sold that motor for 450 was another dummy.The heads were worth more than that.Rocky
Chrysler Firepower
[Re: RV2]
#900358
01/09/11 04:54 PM
01/09/11 04:54 PM
Posts: 5,160 Texas
dannysbee
Texas
Saw that too, must have bought it from a tweeker. Eddy heads and air gap intake, roller rockers and after market roller lifters, demon carb, comp cam and electric water pump. If it was a real deal, they done real good.
Getting old just means you were smarter than some and luckier than others.
[Re: rustbuckett68]
#900360
01/09/11 05:20 PM
01/09/11 05:20 PM
racealittle
I know that the show is entertainment. Most of us would have bought that engine just for the parts if it really was a legitimate sale. We also can kick around everything we saw, and pick it apart.
BUT, I am pretty sure that was a magnum crank from the markings. I don't remember seeing those markings on earlier LA cranks. Someone spent big on that motor.
I just want to really know about the use of LA heads/oiling, on a magnum block/?
[Re: racealittle]
#900361
01/09/11 05:38 PM
01/09/11 05:38 PM
Posts: 5,160 Texas
dannysbee
Texas
You just have to use a lifter that will oil through the push rod. It was a magnum block as it was equipped for lifter retention.
[Re: RV2]
#900365
01/09/11 06:39 PM
01/09/11 06:39 PM
Posts: 1,216 Under My Car
Mopar_Country
Under My Car
I will have to go back and watch the episode but I think those roller lifters had a link attaching them together, even if it was a magnum block still had aftermarket lifters.
I believe they did.
[Re: RV2]
#900366
01/09/11 06:39 PM
01/09/11 06:39 PM
racealittle
Yes, it had aftermarket, linked roller lifters.
I was told that the block would have to be drilled correctly for oil to supply the LA heads. The very few motors that I know of that have attemped that kind of oiling mod, have always had problems.
I have a very good set of LA MCH cnc eddies that I would like to use on a roller cam magnum block.
I am a big block guy and don't know all of the small block tricks.
[Re: 70AARcuda]
#900367
01/09/11 06:43 PM
01/09/11 06:43 PM
racealittle
magnum block...LA heads..not going to work by oiling thru pushrod...
how is oil presssure going to get to shaft????
were they using eddy magnum heads maybe? since eddy magnums use stud mounted small block chevy rockers?
quote]
They were shaft mount rockers and it used a traditional LA airgap intake. I was watching for those details.
[Re: 70AARcuda]
#900369
01/09/11 07:08 PM
01/09/11 07:08 PM
Posts: 377 Michigan Troll
blk00rt
Michigan Troll
the block had the holes for a crank sensor on it, it was also black originally which makes it a magnum block right?
Rob Dunn 1976 Dart Sport 360 2000 dakota RT 408 with 150 nitrous 2013 Dodge Ram 1500 Hemi 2009 Jeep Patriot
[Re: blk00rt]
#900370
01/09/11 07:12 PM
01/09/11 07:12 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Did the TBI engines use a crank sensor back there?
[Re: blk00rt]
#900371
01/09/11 07:12 PM
01/09/11 07:12 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
i have two 91 LA blocks that take roller lifters..both have the mount for the crank sensor...just went and looked at them..
both are MP 360 crate shortlbocks..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: blk00rt]
#900372
01/09/11 07:15 PM
01/09/11 07:15 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
No, early 90's (and late 80's?) pre-magnum engines were black also.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: feets]
#900374
01/09/11 07:20 PM
01/09/11 07:20 PM
Posts: 526 orange,tx
onebadstepside
orange,tx
I thought the engine was built several years ago for their project barracuda....No way they bought that engine for $450.
Small blocks rule!!!!!
