Horsepower TV 360 budget build show? #900355
01/09/11 04:42 PM
01/09/11 04:42 PM
Southwestern Ontario Canada
racealittle Offline OP
Anyone see the new episode this weekend?
Apparently bought a hurt motor with very good parts for something like $450.
Looks like a magnum block and crank with LA eddy heads. roller cam, etc.
How do you get LA heads to oil properly with a magnum block?
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: Horsepower TV 360 budget build show? [Re: racealittle] #900356
01/09/11 04:46 PM
01/09/11 04:46 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
I was waiting for somebody to post about this, how could that be real world? paying $475 for an aluminum headed roller cammed roller rocker small block!
Re: Horsepower TV 360 budget build show? [Re: racealittle] #900357
01/09/11 04:48 PM
01/09/11 04:48 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I laughed when they drained the pan and said all the water that gushed out was condensation.What a bunch of rubes.Whoever sold that motor for 450 was another dummy.The heads were worth more than that.Rocky
Chrysler Firepower
Re: Horsepower TV 360 budget build show? [Re: RV2] #900358
01/09/11 04:54 PM
01/09/11 04:54 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Saw that too, must have bought it from a tweeker. Eddy heads and air gap intake, roller rockers and after market roller lifters, demon carb, comp cam and electric water pump. If it was a real deal, they done real good.
Getting old just means you were smarter than some and luckier than others.
Re: Horsepower TV 360 budget build show? [Re: racealittle] #900359
01/09/11 05:06 PM
01/09/11 05:06 PM
Alberta
rustbuckett68 Offline
Alberta
Wasn't there something about a neutral balancer on the engine that they had to change to an external balanced one? But I would like to know where they shop. And they reused the rings, and still made good power. Kinda funny.
Re: Horsepower TV 360 budget build show? [Re: rustbuckett68] #900360
01/09/11 05:20 PM
01/09/11 05:20 PM
I know that the show is entertainment. Most of us would have bought that engine just for the parts if it really was a legitimate sale.
We also can kick around everything we saw, and pick it apart.
BUT, I am pretty sure that was a magnum crank from the markings. I don't remember seeing those markings on earlier LA cranks. Someone spent big on that motor.
I just want to really know about the use of LA heads/oiling, on a magnum block/?
Re: Horsepower TV 360 budget build show? [Re: racealittle] #900361
01/09/11 05:38 PM
01/09/11 05:38 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
You just have to use a lifter that will oil through the push rod. It was a magnum block as it was equipped for lifter retention.
Re: Horsepower TV 360 budget build show? [Re: dannysbee] #900362
01/09/11 06:10 PM
01/09/11 06:10 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
You know those shows are basically infomercials.
Since when has the truth been an issue for tv ratings.
Re: Horsepower TV 360 budget build show? [Re: dannysbee] #900363
01/09/11 06:11 PM
01/09/11 06:11 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
I will have to go back and watch the episode but I think those roller lifters had a link attaching them together, even if it was a magnum block still had aftermarket lifters.
Re: Horsepower TV 360 budget build show? [Re: dannysbee] #900364
01/09/11 06:33 PM
01/09/11 06:33 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
magnum block...LA heads..not going to work by oiling thru pushrod...
how is oil presssure going to get to shaft????
were they using eddy magnum heads maybe?
since eddy magnums use stud mounted small block chevy rockers?
Tony
70 AARCuda Vitamin C
Re: Horsepower TV 360 budget build show? [Re: RV2] #900365
01/09/11 06:39 PM
01/09/11 06:39 PM
Under My Car
Mopar_Country Offline
Under My Car
I believe they did.
Re: Horsepower TV 360 budget build show? [Re: RV2] #900366
01/09/11 06:39 PM
01/09/11 06:39 PM
Yes, it had aftermarket, linked roller lifters.
I was told that the block would have to be drilled correctly for oil to supply the LA heads. The very few motors that I know of that have attemped that kind of oiling mod, have always had problems.
I have a very good set of LA MCH cnc eddies that I would like to use on a roller cam magnum block.
I am a big block guy and don't know all of the small block tricks.
Re: Horsepower TV 360 budget build show? [Re: 70AARcuda] #900367
01/09/11 06:43 PM
01/09/11 06:43 PM
quote]
They were shaft mount rockers and it used a traditional LA airgap intake. I was watching for those details.
Re: Horsepower TV 360 budget build show? [Re: racealittle] #900368
01/09/11 07:00 PM
01/09/11 07:00 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
quote]
Probably was a 89-91 360 pre-magnum block that has the lifter retention ...spider and dogbones...but still uses the LA cylinder heads with shaft rockers...
Tony
Re: Horsepower TV 360 budget build show? [Re: 70AARcuda] #900369
01/09/11 07:08 PM
01/09/11 07:08 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
the block had the holes for a crank sensor on it, it was also black originally which makes it a magnum block right?
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: Horsepower TV 360 budget build show? [Re: blk00rt] #900370
01/09/11 07:12 PM
01/09/11 07:12 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Did the TBI engines use a crank sensor back there?
- Stu Harmon
Re: Horsepower TV 360 budget build show? [Re: blk00rt] #900371
01/09/11 07:12 PM
01/09/11 07:12 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
i have two 91 LA blocks that take roller lifters..both have the mount for the crank sensor...just went and looked at them..
both are MP 360 crate shortlbocks..
Tony
Re: Horsepower TV 360 budget build show? [Re: blk00rt] #900372
01/09/11 07:15 PM
01/09/11 07:15 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
No, early 90's (and late 80's?) pre-magnum engines were black also.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Horsepower TV 360 budget build show? [Re: GO_Fish] #900373
01/09/11 07:19 PM
01/09/11 07:19 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
so because they were not painted black they are not pre-magnums...?
so went i painted my 91 pre-magnum block blue it is no longer a pre-magnum?...LOL
Tony
Re: Horsepower TV 360 budget build show? [Re: feets] #900374
01/09/11 07:20 PM
01/09/11 07:20 PM
orange,tx
O
onebadstepside Offline
O
orange,tx
I thought the engine was built several years ago for their project barracuda....No way they bought that engine for $450.
Small blocks rule!!!!!
