Who sells correct Goodyear White line polyglas tires #900260
01/09/11 02:25 PM
01/09/11 02:25 PM
vancouver wa
mad car disease Offline OP
vancouver wa
Looking for a correct set of Goodyear Whiteline polyglas F70-14 code T82 tires. Or does anyone have a set of radial tires with the correct white lines like they have for Redlines?
Re: Who sells correct Goodyear White line polyglas tires [Re: mad car disease] #900261
01/09/11 02:41 PM
01/09/11 02:41 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
You can probably get them made. Radials that is. Here is my friend's '67 Coronet where he thad twin blue lines made for it. They're basically a generic tire where they cut in the whitewalls and then dyed them. I had wide whitewalls made the same way several years ago. Almost all tires have a white inner rubber layer that they can cut down to. I believe the original thin whitewalls were actually a raised white rib instead of recessed.
Re: Who sells correct Goodyear White line polyglas tires [Re: mad car disease] #900262
01/09/11 02:44 PM
01/09/11 02:44 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Re: Who sells correct Goodyear White line polyglas tires [Re: FJ5_Fish] #900263
01/09/11 03:00 PM
01/09/11 03:00 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
T82 - isn't POLYGLAS
1969 b-bodies with the T82 tire (F70-14 "white stripe") were in most cases Goodyear SPEEDWAY - a Nylon Cord tire. Some Firestone Wide Ovals (Nylon Cord) were used at some plants or late in the model year.
All of the reproduction Goodyear SPEEDWAY (Kelsey Tire) & Firestone Wide Oval (Coker Tire) tires are fiberglass belted.
Re: Who sells correct Goodyear White line polyglas tires [Re: FJ5_Fish] #900264
01/09/11 03:00 PM
01/09/11 03:00 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
Click Here
A good reproduction but not exactly as the T82.
There is a place that sells original unused tires that may still have what you are looking for..
http://www.buycheaptiresandwheels.com/home.php
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: Who sells correct Goodyear White line polyglas tires [Re: NicksGarage] #900265
01/09/11 03:04 PM
01/09/11 03:04 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
I thought it was the other way around?
The Redlines I had made from Diamond Back Classics (same place where it looks like the dual blue stripes were made)have the lines actually vulcanized to the outer wall...they are raised up.
The originals had the white or red or blue lines "cut" into the side wall....
1MYTGTX
Re: Who sells correct Goodyear White line polyglas tires [Re: 1MYTGTX] #900266
01/09/11 04:32 PM
01/09/11 04:32 PM
MO
cdp Offline
cdp  Offline
MO
Contact Rusty Small (smallhurst) here on the board. He is getting discounts on Kelsey Tire products.
https://board.moparts.org/ubbthreads/show...e=0#Post5112944
Re: Who sells correct Goodyear White line polyglas tires [Re: mad car disease] #900267
01/09/11 04:45 PM
01/09/11 04:45 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
I got mine from Kelsey Tire
CHECK OUT MY NEW WEB SITE !
