Re: old 392 hemi?
[Re: rowin4]
#900044
01/09/11 04:55 AM
01/09/11 04:55 AM
Posts: 2,840 Flint, Michigan
B1Fish540
Flint, Michigan
I consider the bore space as the indicator of small block or BIG block. heres is some info i got from the rodders forum: Quote:
325 Dodge hemi already has a 3.80" stroke. To get 390 cubes, you'd need about a 4.5" stroke.
Problem with the early Dodge hemi is that its bore center-to-center distance(bore space) - 4.1875 inches - is one of the smallest of any V-8 ever (the Ford 4.6-5.4 modular V-8 is smaller).
By comparison, a SBC is 4.40 inches, SB Mopar is 4.46, and a BB Mopar is 4.80 inches.
So all the early Dodge hemis are small-bore engines, and the small bore limits its cubic inch potential.
The early De Soto hemi was also limited in size potential, just not quite as limited as the Dodge. Its 4.3125" bore center distance you will note is still less than either a small block Chevy or Mopar.
And just FYI, the Chrysler 331-354-392 hemi had a 4.5625" bore spacing.
So, like Cab said, its in between a BB and a SB...interstingly, its actually about .200 closer to a small block!
Re: old 392 hemi?
[Re: polyspheric]
#900048
01/09/11 12:26 PM
01/09/11 12:26 PM
Posts: 3,695 nc
emarine01
nc
Thankx Jeff... good info .... I see some around 416 cubes floating around. Can you get any rpm out of that set up, it seems like a small block with a long rod, Do they make lighter parts, Alu heads & intake? How far can you push the bore size? Are the factory cranks forged?
Re: old 392 hemi?
[Re: Handygun]
#900050
01/09/11 02:34 PM
01/09/11 02:34 PM
Posts: 4,206 New York
polyspheric
New York
The 426 designers didn't have the clean sheet of paper to work with, and the valve gear is a compromise to use as much RB tooling as possible.
Boffin Emeritus
Re: old 392 hemi?
[Re: polyspheric]
#900051
01/09/11 02:36 PM
01/09/11 02:36 PM
Posts: 862 Iowa State fan
kilroy
Iowa State fan
You can use sb spec springs in stock application, sb distributor, sb timing chain also.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: old 392 hemi?
[Re: emarine01]
#900053
01/09/11 02:52 PM
01/09/11 02:52 PM
kilroy
Iowa State fan
the Hot Heads guys made great power out of a 331 for the Engine Master challenge, given it was a single 4 but.... still NA
Re: old 392 hemi?
[Re: kilroy]
#900054
01/09/11 08:33 PM
01/09/11 08:33 PM
Posts: 2,129 Vermont
TrWaters
Vermont
Think of it as a tall deck small block. An all new aluminum early hemi 392 block is due out later this year.
TR Waters
Re: old 392 hemi?
[Re: emarine01]
#900056
01/09/11 09:57 PM
01/09/11 09:57 PM
B1Fish540
Flint, Michigan
Small block Mopars give up 40 cubes to Chevy and 30 cubes to ford, I guess the new hemis are small blocks This old 392 hemi being in between sounds more like racing politics to me
no, the SB mopars actually are bigger than the Chev( and will accept a bigger valve), thats actually helped them in nascar. The SB mopars dominate in World of Outlaw racing as well.
