old 392 hemi? #900041
01/09/11 02:35 AM
01/09/11 02:35 AM
nc
E
emarine01 Offline OP
E
nc
What is a old 392... Big block... small block.... or something in between, it kinda looks like a small block with lots of deck height
Re: old 392 hemi? [Re: emarine01] #900042
01/09/11 02:45 AM
01/09/11 02:45 AM
It's a 392, not a BB, not a SB The original Chrysler Hemi V8s started life as a 331 C.I. passnger car motor,not considered for racing until 1955 And then things went crazy
Re: old 392 hemi? [Re: Cab_Burge] #900043
01/09/11 03:38 AM
01/09/11 03:38 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
It may not be a big block or a small block but every one will agree their a heavy block
Re: old 392 hemi? [Re: rowin4] #900044
01/09/11 04:55 AM
01/09/11 04:55 AM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
I consider the bore space as the indicator of small block or BIG block. heres is some info i got from the rodders forum:
325 Dodge hemi already has a 3.80" stroke. To get 390 cubes, you'd need about a 4.5" stroke.
Problem with the early Dodge hemi is that its bore center-to-center distance(bore space) - 4.1875 inches - is one of the smallest of any V-8 ever (the Ford 4.6-5.4 modular V-8 is smaller).
By comparison, a SBC is 4.40 inches, SB Mopar is 4.46, and a BB Mopar is 4.80 inches.
So all the early Dodge hemis are small-bore engines, and the small bore limits its cubic inch potential.
The early De Soto hemi was also limited in size potential, just not quite as limited as the Dodge. Its 4.3125" bore center distance you will note is still less than either a small block Chevy or Mopar.
And just FYI, the Chrysler 331-354-392 hemi had a 4.5625" bore spacing.
So, like Cab said, its in between a BB and a SB...interstingly, its actually about .200 closer to a small block!
Re: old 392 hemi? [Re: emarine01] #900045
01/09/11 05:46 AM
01/09/11 05:46 AM
York,Pa
Slap Shot Offline
Slap Shot  Offline
York,Pa
a small block mopar trans will bolt up to it using a adapter plate
Re: old 392 hemi? [Re: Slap Shot] #900046
01/09/11 06:05 AM
01/09/11 06:05 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...Its also considered a raised deck @ 10.87", ~1/2" over the 354.
...Memory is bad, but seems like the sb timing set & dizzy will work on it.
Re: old 392 hemi? [Re: emarine01] #900047
01/09/11 09:56 AM
01/09/11 09:56 AM
New York
polyspheric Offline
polyspheric  Offline
New York
The tooling is far closer to LA: rear distributor, cam to crank distance, oil pump location.
More data from my site:
http://victorylibrary.com/mopar/m-table-c.htm#Dodge
Boffin Emeritus
Re: old 392 hemi? [Re: polyspheric] #900048
01/09/11 12:26 PM
01/09/11 12:26 PM
nc
E
E
nc
Thankx Jeff... good info .... I see some around 416 cubes floating around. Can you get any rpm out of that set up, it seems like a small block with a long rod, Do they make lighter parts, Alu heads & intake? How far can you push the bore size? Are the factory cranks forged?
Re: old 392 hemi? [Re: emarine01] #900049
01/09/11 01:22 PM
01/09/11 01:22 PM
STL ,MO
Handygun Offline
Handygun  Offline
STL ,MO
It's an outgrowth of Chryslers first OHV v-8, there are alum heads&intakes new from Hot Heads, it would have to be in history second only to the 426 style Hemi in Top fuel and Funnycar wins. There is a large contingent that think it's the best V-8 ever made as engineering ruled over cost. Racers& upper end racing parts manufacturers who made thier bones with the early Hemi is a who's who of drag racing.Today expect to spend alot of cash and have adapters that bolt to adapters to run a 92' with modern parts.But it can be done.
Re: old 392 hemi? [Re: Handygun] #900050
01/09/11 02:34 PM
01/09/11 02:34 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The 426 designers didn't have the clean sheet of paper to work with, and the valve gear is a compromise to use as much RB tooling as possible.
Boffin Emeritus
Re: old 392 hemi? [Re: polyspheric] #900051
01/09/11 02:36 PM
01/09/11 02:36 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
You can use sb spec springs in stock application, sb distributor, sb timing chain also.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: old 392 hemi? [Re: kilroy] #900052
01/09/11 02:48 PM
01/09/11 02:48 PM
nc
E
E
nc
hunting around the net it seems that most of the 392 builds favored older technology, forced induction or fuel injection. Anyone find a newer build that's NA using newer parts, Seems like if the heads are around you could make some real power from that block with a single 4.
Re: old 392 hemi? [Re: emarine01] #900053
01/09/11 02:52 PM
01/09/11 02:52 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
the Hot Heads guys made great power out of a 331 for the Engine Master challenge, given it was a single 4 but.... still NA
Re: old 392 hemi? [Re: kilroy] #900054
01/09/11 08:33 PM
01/09/11 08:33 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
Think of it as a tall deck small block.
An all new aluminum early hemi 392 block is due out later this year.
TR Waters
Re: old 392 hemi? [Re: TrWaters] #900055
01/09/11 08:59 PM
01/09/11 08:59 PM
nc
E
E
nc
Small block Mopars give up 40 cubes to Chevy and 30 cubes to ford, I guess the new hemis are small blocks This old 392 hemi being in between sounds more like racing politics to me
Re: old 392 hemi? [Re: emarine01] #900056
01/09/11 09:57 PM
01/09/11 09:57 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
no, the SB mopars actually are bigger than the Chev( and will accept a bigger valve), thats actually helped them in nascar. The SB mopars dominate in World of Outlaw racing as well.
Re: old 392 hemi? [Re: B1Fish540] #900057
01/09/11 10:16 PM
01/09/11 10:16 PM
nc
E
E
nc
I was thinking about the old factory blocks 400 chev, 390 ford, 360 mopar, I cant run a race block in my class, seems the 392 fits the factory block part
Re: old 392 hemi? [Re: emarine01] #900058
01/10/11 12:01 AM
01/10/11 12:01 AM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Oh, OK. Never heard of a 390 Ford SB, but that doesnt mean anything, lol. I think the 400 chev was possble because it had siameezed bores.(no water jacket)
Re: old 392 hemi? [Re: B1Fish540] #900059
01/10/11 12:02 AM
01/10/11 12:02 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
They are expensive tall deck small blocks....
