904 clutch disc clearance #899785
01/08/11 06:37 PM
01/08/11 06:37 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
How much clearance do I need on the front drum with 5 discs and 4 discs in the other.
I have race discs...
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: 904 clutch disc clearance [Re: DemonDust] #899786
01/08/11 09:44 PM
01/08/11 09:44 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Forward (the one @ the rear) - .028"-.034"
High gear clutch pack - .060"-.070"
Re: 904 clutch disc clearance [Re: DemonDust] #899787
01/08/11 09:47 PM
01/08/11 09:47 PM
CT
turbocolt2.4L Offline
CT
I run .050-.060 w/5 direct friction solid snap ring and the forwards i run .020 i havent had any problems with either well over 140 chassis dyno pulls and a ton of track time they look new 160 psi line pressure turbo 4cyl 600RWHP.
Re: 904 clutch disc clearance [Re: turbocolt2.4L] #899788
01/08/11 10:43 PM
01/08/11 10:43 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I built a E/SA 904 2 decades ago. That is the only 904/999 trans I have touched. However, from the 727 info I have collected, I would run .015 per disc on the front clutch, and .006 on the rear.
Re: 904 clutch disc clearance [Re: Leigh] #899789
01/09/11 06:32 PM
01/09/11 06:32 PM
Menomonee Falls
Menomonee Falls
Thanks for the info guys!!!
SDG Motorsports
