alterkation power steering? #899633
01/08/11 04:16 PM
01/08/11 04:16 PM
Tampa FL
hemibeep Offline OP
hemibeep  Offline OP
Tampa FL
does anyone have this setup? it is alterkation power steering. It seems to "stick" sometimes and does not always turn smooth. any ideas?
using factory power steering pump from 6.1 hemi.
thanks
Re: alterkation power steering? [Re: hemibeep] #899634
01/08/11 04:27 PM
01/08/11 04:27 PM
Costa Mesa, CA
chache876 Offline
chache876  Offline
Costa Mesa, CA
this may not apply to you but once on a stock power steering setup, mine would stick sometimes, usually turning right.
Turns out what was happening was the steering coupler was too close to the headers. Whenever I would turn the wheel right, the square ends of the coupler would hit the header, basically stopping the wheel from turning.
Might be something to check out.
Re: alterkation power steering? [Re: chache876] #899635
01/08/11 04:40 PM
01/08/11 04:40 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Along those lines, check if the steering coupler or U-joints are lubed or have lube if they are permenantly lubed.
Also double check if all your suspension parts with zerks are lubed. (I've forgot that once).
Re: alterkation power steering? [Re: autoxcuda] #899636
01/09/11 01:28 PM
01/09/11 01:28 PM
Portland,OR
rjsjea Offline
rjsjea  Offline
Portland,OR
When i was buying parts for my setup (6.1/alterK)I was told the factory pump pressure was too much for the AlterK rack. Bouchillon Perf sells a fitting to correct it.
Giving RMS a call might be a good call also.....they use to use Flaming River racks but went with AGR in the last couple years.
Re: alterkation power steering? [Re: rjsjea] #899637
01/09/11 03:05 PM
01/09/11 03:05 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Ive had no problem with a factory older pump (77) no sticks or??? But was also told to be aware of the possible pressure issue.
Alot of the time I run with the ps belt off and with the system full of fluid its almost as easy as a manual box and I think its a lil more quick ratio then there std manual rack.
Do you know who made your rack, FR maybe id almost call them and get the pressure specs.
I cant see your steering linkage in a bind as its very straight forward, I had to weld the main shaft eyelet bracket onto my frame as
the power rack shaft sits 2 inches further out then a non power rack.
