Will this gear be right for me? #897773
01/06/11 02:03 PM
01/06/11 02:03 PM
St. Clair Shores, Michigan
bigsbigelow Offline OP
My Duster ran a best of 12.67 at 107 mph with a 1.9 sixty foot last summer. I want to optimize my combo during the off season. Currently the car has a 741 case with a broken Sure-Grip and 3.91 gear (Found out the Sure-Grip was broke at Milans all Mopar day. Embarrassing to say the least). I am definitely going to upgrade to a 742 case with a spool. I want to turn 6500 rpm through the traps and I run a 27" tall tire. I am thinking 4.30's will be good. You guys have never steered me wrong so I thought I would consult the experts before I made a move.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Will this gear be right for me? [Re: bigsbigelow] #897774
01/06/11 02:05 PM
01/06/11 02:05 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
4.30's or 4.56's will work, what engine, what cam type (it makes a difference), what transmission?
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: Will this gear be right for me? [Re: Slingshot383] #897775
01/06/11 02:12 PM
01/06/11 02:12 PM
It is a 340 with a Comp Cams Xtreme Energy XS282S (.520 / .540 lift and 244 / 252 duration at .050) and 10.5:1 compression. The trans is a 727 with stock gears and a 9.5" PTC 3500 rpm converter. I do a lot of street driving with the car as well.
Re: Will this gear be right for me? [Re: bigsbigelow] #897776
01/06/11 02:16 PM
01/06/11 02:16 PM
Get-X Offline
Get-X  Offline
It is a 340 with a Comp Cams Xtreme Energy XS282S and 10.5:1 compression. The trans is a 727 with stock gears and a 9.5" PTC 3500 rpm converter. I do a lot of street driving with the car as well.
I would be using a 4.10 if it were mine.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: Will this gear be right for me? [Re: bigsbigelow] #897777
01/06/11 02:19 PM
01/06/11 02:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Here's a handy calculator BUT remember to add in the
converter slippage
http://www.richmondgear.com/01calculators.html
Re: Will this gear be right for me? [Re: MR_P_BODY] #897778
01/06/11 02:28 PM
01/06/11 02:28 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
when i ran my 340 last yr i had 28/10.5 slicks and 4.57 gears and would turn 62/6300 in the 1/8 mile so i think 4.30 would be better in your case jmop mike
Re: Will this gear be right for me? [Re: earthmover] #897779
01/06/11 02:33 PM
01/06/11 02:33 PM
Get-X Offline
Get-X  Offline
I agree that the 4.30 is the best gear at the track, but they aren't great for street use. If the car is mostly a drag racer and only occasionly sees the street, than the 4.30 would be perfect. If it's mostly a street car that goes to the track once or twice a year use the 4.10 IMO.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: Will this gear be right for me? [Re: Get-X] #897780
01/06/11 02:48 PM
01/06/11 02:48 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
I have a 4.30 with 28" tires in mine now and while it's great at the track I'm thinking of swapping it for a 3.91 to enhance my street driving.
A 340 will love the gear, i now have a 416 so I think I can use abit less gear.
Gary
Re: Will this gear be right for me? [Re: Get-X] #897781
01/06/11 03:01 PM
01/06/11 03:01 PM
I guess I should mention that I can tolerate losing some "street-ability" for a faster car. There is a group of tuner guys that I am friends with. I want to be able to inch them out at the track with an all motor combo. 12 flat is the fastest car in the group. I think i can reach that with the correct gear.
Re: Will this gear be right for me? [Re: bigsbigelow] #897782
01/06/11 04:18 PM
01/06/11 04:18 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
4.30 i've got a buddy that loves them and they work great for him and he drives it alot ..i have even drove my little mess a few times and it didnt bother me at all never ran hot but its all in what you will live with and what you would like to do with the car....
Re: Will this gear be right for me? [Re: bigsbigelow] #897783
01/06/11 04:51 PM
01/06/11 04:51 PM
Ohio
aquamist60 Offline
aquamist60  Offline
Ohio
Last year we ran a 340 Duster with 28" tall slicks & a 4:56 gear. Had a best 60' @ 1.68, 1/8 mile 7.71 @ 90.98 mph, 1/4 mile was a 12.19 @ 109. Shifted @ 6200 & crossed the line @ 6500 rpm.
It's mostly a stock short block with stock iron heads. I'm thinking we've still got about another .3 in the 1/4 left on the table.
Re: Will this gear be right for me? [Re: bigsbigelow] #897784
01/06/11 09:32 PM
01/06/11 09:32 PM
oklahoma
forphorty Online content
forphorty  Online Content
oklahoma
If your stall speed is really only 3500,I think a looser convertor (4500ish} would pick up more than any gear change.
Re: Will this gear be right for me? [Re: bigsbigelow] #897785
01/06/11 09:36 PM
01/06/11 09:36 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Not to be Debbie Downer, but you'll need to find more hp to go 12.0 or faster, the 107 mph indicates not enough hp.
Be sure to check with guys running a spool on the street, as some don't like it.
Re: Will this gear be right for me? [Re: BSB67] #897786
01/07/11 11:20 AM
01/07/11 11:20 AM
You don't think so? That 107 mph was at 5800 rpm. That is why I want a gear change. Shoot, I shift higher than I trap. I have also driven a couple cars with a spool. I can definitely notice the difference but it doesn't bother me.
Re: Will this gear be right for me? [Re: bigsbigelow] #897787
01/07/11 01:28 PM
01/07/11 01:28 PM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
I would stay away from the spool unless you have some good axels. A good sure grip would be better suited for a strip street car.
6.50 @105.26
Re: Will this gear be right for me? [Re: forphorty] #897788
01/08/11 11:51 AM
01/08/11 11:51 AM
NC
440Jim Offline
440Jim  Offline
NC
Re: Will this gear be right for me? [Re: bigsbigelow] #897789
01/08/11 04:04 PM
01/08/11 04:04 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
No, I don't think so. We've done this a few times and when nothing else is changed, and you adjust appropriately for atmospheric conditions, it might be 1 mph. And if you go with the gear that gives you the very best et, you might be down a little in mph. Going to a spool might few up a few ponies - I don't know.
Try it and report back. It's always good to have data from well controlled test conditions. It will be quicker. And if I'm mistaken, I'd like to know that too.
Re: Will this gear be right for me? [Re: BSB67] #897790
01/08/11 04:19 PM
01/08/11 04:19 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
Loc: Ohio Re: Will this gear be right for me? [Re: bigsbigelow]
#6401288 - Thu Jan 06 2011 02:51 PM Edit Reply Quote Quick Reply
my 340 was a little more then stock about 11.1 comp. and 520/540 soild cam mild heads but ran a best of 7.44 at 89.9 with a 1.67 60' which was not the best 60' i think it had more in it with some frontend workand a new set of slicks ( check holes was gone on the set i had) but ill never know i sold the short block...your mph is better with about the same 60' so hard to say...but i think the 4/30 is a preety good gear as well. mike
Re: Will this gear be right for me? [Re: bigsbigelow] #897791
01/08/11 04:32 PM
01/08/11 04:32 PM
Cab_Burge Online work
Cab_Burge  Online Work
Fix the posi first Once that is done make your decesion I would look at two third members, one for street and one for racing as far as the right ratio and finish line RPM find out where the car likes being shifted out of first and second gears by looking at the 330 and 660 ft. times and MPH Most stock lie SB like being shifted around 6300 to 6700 RPM, the steeper rear gears will help it some on the top end but they are not a cure all Maybe 9secondPhil will chime in on his fisrt "Cab" car and the results of changing the rear gears from 3:55 to 4:89, not much if I'm remembering correctly
Re: Will this gear be right for me? [Re: Cab_Burge] #897792
01/10/11 08:51 AM
01/10/11 08:51 AM
Thanks for all the insight guys. I was thinking gear change because I wanted to get rid of my 741 case. I have read and heard some bad things about the 741. Is it all that bad? If not, I will just rebuild the sure-grip and save some coin.
