Re: Will this gear be right for me?
[Re: bigsbigelow]
#897774
01/06/11 02:05 PM
01/06/11 02:05 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
4.30's or 4.56's will work, what engine, what cam type (it makes a difference), what transmission?
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: Slingshot383]
#897775
01/06/11 02:12 PM
01/06/11 02:12 PM
Posts: 1,564 St. Clair Shores, Michigan
bigsbigelow
It is a 340 with a Comp Cams Xtreme Energy XS282S (.520 / .540 lift and 244 / 252 duration at .050) and 10.5:1 compression. The trans is a 727 with stock gears and a 9.5" PTC 3500 rpm converter. I do a lot of street driving with the car as well.
[Re: Get-X]
#897781
01/06/11 03:01 PM
01/06/11 03:01 PM
bigsbigelow
when i ran my 340 last yr i had 28/10.5 slicks and 4.57 gears and would turn 62/6300 in the 1/8 mile so i think 4.30 would be better in your case jmop mike
I agree that the 4.30 is the best gear at the track, but they aren't great for street use. If the car is mostly a drag racer and only occasionly sees the street, than the 4.30 would be perfect. If it's mostly a street car that goes to the track once or twice a year use the 4.10 IMO.
I guess I should mention that I can tolerate losing some "street-ability" for a faster car. There is a group of tuner guys that I am friends with. I want to be able to inch them out at the track with an all motor combo. 12 flat is the fastest car in the group. I think i can reach that with the correct gear.
[Re: BSB67]
#897786
01/07/11 11:20 AM
01/07/11 11:20 AM
bigsbigelow
Not to be Debbie Downer, but you'll need to find more hp to go 12.0 or faster, the 107 mph indicates not enough hp.
Be sure to check with guys running a spool on the street, as some don't like it.
You don't think so? That 107 mph was at 5800 rpm. That is why I want a gear change. Shoot, I shift higher than I trap. I have also driven a couple cars with a spool. I can definitely notice the difference but it doesn't bother me.
[Re: forphorty]
#897788
01/08/11 11:51 AM
01/08/11 11:51 AM
Posts: 16,925 NC
440Jim
NC
If your stall speed is really only 3500,I think a looser convertor (4500ish} would pick up more than any gear change.
[Re: bigsbigelow]
#897789
01/08/11 04:04 PM
01/08/11 04:04 PM
Posts: 4,313 Prospect, PA
BSB67
Prospect, PA
No, I don't think so. We've done this a few times and when nothing else is changed, and you adjust appropriately for atmospheric conditions, it might be 1 mph. And if you go with the gear that gives you the very best et, you might be down a little in mph. Going to a spool might few up a few ponies - I don't know.
Try it and report back. It's always good to have data from well controlled test conditions. It will be quicker. And if I'm mistaken, I'd like to know that too.
[Re: BSB67]
#897790
01/08/11 04:19 PM
01/08/11 04:19 PM
Posts: 2,449 nc
earthmover
nc
Loc: Ohio Re: Will this gear be right for me? [Re: bigsbigelow] #6401288 - Thu Jan 06 2011 02:51 PM Edit Reply Quote Quick Reply Last year we ran a 340 Duster with 28" tall slicks & a 4:56 gear. Had a best 60' @ 1.68, 1/8 mile 7.71 @ 90.98 mph, 1/4 mile was a 12.19 @ 109. Shifted @ 6200 & crossed the line @ 6500 rpm. It's mostly a stock short block with stock iron heads. I'm thinking we've still got about another .3 in the 1/4 left on the table. my 340 was a little more then stock about 11.1 comp. and 520/540 soild cam mild heads but ran a best of 7.44 at 89.9 with a 1.67 60' which was not the best 60' i think it had more in it with some frontend workand a new set of slicks ( check holes was gone on the set i had) but ill never know i sold the short block...your mph is better with about the same 60' so hard to say...but i think the 4/30 is a preety good gear as well. mike
