Re: 4speed a833 wont downshift into 2nd gear [Re: 440challenger] #897343
08/16/11 09:29 AM
08/16/11 09:29 AM
Michgian
moparfun340 Offline
moparfun340  Offline
Michgian
Did you find the problem with the down shift. I have the same problem.
Re: 4speed a833 wont downshift into 2nd gear [Re: moparfun340] #897344
04/30/12 07:45 PM
04/30/12 07:45 PM
Minnesota
Shawnb Offline
Shawnb  Offline
Minnesota
Im having the same problem too. Any results to the above problem? Thanks
Re: 4speed a833 wont downshift into 2nd gear [Re: Shawnb] #897345
05/07/12 04:29 PM
05/07/12 04:29 PM
Central Ohio
Ledman_70 Offline
Ledman_70  Offline
Central Ohio
This is probably unrelated, but back in the 70's my 69 RR liked to jump outta 3rd during deceleration after downshifting. I tore it apart to find the rear main bearing between the body and tail housing was bad. After I replaced that and the synchro rings it shifter great.
Jeff Adams 64 426 Polara
