Re: super stock cars running turbo 400 guts n 727?
[Re: DaKuda]
#896656
01/05/11 01:35 PM
01/05/11 01:35 PM
Posts: 762 Southington Ct.
turbobitt
Southington Ct.
I always thought they ran specially machined 904 type parts in a 727. Wouldn't make much sense to use TH400 stuff since many of the high HP 400 convert to spragless type direct/intermediate drum making it more like a 727.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: Spode]
#896658
01/05/11 02:19 PM
01/05/11 02:19 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
ProFlite ?
For the ultimate in race 727 technology. The ProFlite transmissions are for use in NHRA's Comp Eliminator and Super Stock Modified cars, regardless of the brand of transmission the car originally came with. ProFlites are designed to fit wherever a Powerglide once resided. Based on smaller AMC 727 casings (which are narrower in the bellhousing region by 1.5 inches) and featuring light-weight 904-based internal components, these transmissions are so efficient they require only 125 to 150 psi of line pressure to function compared to the 225 psi required in the race 'Glides. The lower the pressure, the less power is wasted turning the pump. The ProFlites are available with 25 different gear-ratio combinations, are available with a billet aluminum adapter to fit Chevrolet engines that allow the use of Powerglide torque converters, and are able to withstand up to 1,300 hp.
SPODE has it right Call Dave at Pro Trans, 661-940-7400, if you want the best ,latest, greatest racing three speed trans available out there ![](/ubbthreads/images/graemlins/scope.gif)
[Re: 6440nssa]
#896660
01/05/11 08:35 PM
01/05/11 08:35 PM
Posts: 242 Upland, California
Spode
Upland, California
how does people come up with this?
I used the cut and paste method ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: Spode]
#896661
01/05/11 10:34 PM
01/05/11 10:34 PM
Posts: 10,049 MN
JERICOGTX
MN
I know a couple FORD's that run stock Eliminator. C6 case, torqueflite guts... They have been doing it for YEARS...
69 GTX
68 Road Runner
[Re: JERICOGTX]
#896662
01/06/11 12:25 AM
01/06/11 12:25 AM
Posts: 2,611 Elbridge, NY
Dart1031
Elbridge, NY
I heard about this too. But I also heard that it somehow eliminates "park" in the trans. The tech guys made the drivers put the car in park, if it rolled when they pushed it, it was DQ'd.
[Re: JERICOGTX]
#896663
01/06/11 12:37 AM
01/06/11 12:37 AM
Posts: 673 Emmett, Idaho
SuperStockWagon
Emmett, Idaho
Hmmmm..I've never heard that one before. I knew they were running C4's behind 390/427/428's etc..
[Re: DaKuda]
#896667
01/06/11 04:44 PM
01/06/11 04:44 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
Had a friend who runs SS tell me ALL SS/AH AND OTHERS NOW RUN TURBO 400 guts in 727's. Is this true?
No.
[Re: moderncylinder]
#896669
01/12/11 02:43 PM
01/12/11 02:43 PM
Posts: 1,607 KYbywayof WV
Frito
KYbywayof WV
its the lucas oil sticker they worry about
RIGHT ON. A friend of mine made a time run at Indy. When he retuned to the pits an NHRA official rode up on a mini bike and told me they would let it slide this time but get the Lucas sticker on the car or the run would be DQ.
