Re: Is Original dashpad worth saving?
[Re: BADBEE]
#89623
08/18/08 07:00 AM
08/18/08 07:00 AM
Posts: 444 Loma Linda, MO
7812845
Loma Linda, MO
Is there any company that buys the cores, or do you have to sell them to someone that needs it for a core??
2020 RAM Longhorn 4x4 2022 Jeep Grand Cherokee Overland
[Re: UCUDANT]
#89625
08/18/08 01:59 PM
08/18/08 01:59 PM
Posts: 1,822 Colorado
denfireguy
Colorado
I am having an E body pad done. I bought a core on Ebay from someone in Nebraska for 50 bucks. I cleaned the rust off of it. I had Nick in AZ (Moparts member) take care of the rest with Ultimate Rides. Best price (Moparts group rate) and the most convenient. Nick arranged for pickup by FedEx. Wrapped in shrink, it has been there for a couple of weeks now, will let you know how it turns out. One word of caution, the guy in NE sent the VIN on it still. This is a federal no-no (interstate trafficing of a controlled item). You need to keep the VIN in your posession. Next hard part is the rivets to reinstall and a Moparts member helped me out there (Thanks Pete!). Thank you Moparts, I would be stuck on Ebay for everything. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: jsully]
#89627
08/18/08 05:04 PM
08/18/08 05:04 PM
Posts: 8,139 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
Create a post and ask folks their experiences with these. I have a UR pad that looks pretty good. I do have a gap between the lower edge of the dash in the center, as it does not fully meet the lower dash trim/molding. I may need to remove the pad to ensure there is not some foam that needs to be trimmed. Riveting the VIN tag down can be tricky as there is some foam in that area and my original did not appear to have anything between the vinyl and the frame below the tag I understand results can vary. Overall I like the dash. Theres allot of work involved with creating these and the price is actually pretty good A dash thread https://board.moparts.org/ubbthreads/show...rue#Post4573654
[Re: UCUDANT]
#89629
08/18/08 06:00 PM
08/18/08 06:00 PM
Posts: 4,165 Florida
cataclysm80
I recieved my Ultimate Rides pad fairly quick, and at a good price. It's not fully installed yet, but I have test fit it once, and I'm pretty sure I can live with the quality.
My car is a 70 challenger and Ultimate Rides uses the correct dash script for my application, which was important to me.
There was some extra foam on the inside of the pad which needed to be removed for installation. This is a comon issue with their pads. You just have to do some prep work cleaning it up/test fitting before installation.
Ultimate Rides will make Air Conditioning vent holes in an original metal core if they need an AC dashpad to sell. This is something that Just Dashes refuses to do. Now I know why... To get my AC vents to fit my Ultimate Rides dash pad, I had to enlarge their holes in the metal dash frame with a hack saw blade after receiving it! It's a good thing I had a 100% grade in Geometry class! It's a little tricky figuring which side of a non factory hole to enlarge and still have the vents fit and level to eachother. I had to take about 3/8 inch of frame off top of each hole. Very stressful, but it worked and looks good now. I'm pretty sure the ducting will line up with the vent location just fine.
I sent 2 cores to them on June 10th this year, and have confirmation that they were delivered. After 4 phone calls and more than 2 months, I still have Not recieved the check for my cores! I call during the day, but always seem to have trouble getting ahold of them. The owners voice mail box is full, and the receptionist only seems to answer about half the time. I left another message around 2 this afternoon. It's almost 4 hours later now, they close soon, and still no call back. Customer service leaves a little to be desired.
I've also used Just Dashes and am happy with that product as well. Their 70 E body dash script is not chromed as original, but that only matters if you have a 70 E body. I hear that the grain pattern is more correct on the Ultimate Rides pads, but I didn't notice any grain problems with my Just Dashes pad. I guess I'm not a stickler for that sort of thing. Just Dashes is expensive, and it takes a long time to get the finished product, I think because they have a waiting list. No trimming or cleaning was required. It installed without any problems. A few years later, a small flap of vinyl came unglued where it was rolled under by the left side of the instrument cluster, but I glued it back in place and haven't had any problems since.
Tav
[Re: ricomondo]
#89631
08/18/08 06:18 PM
08/18/08 06:18 PM
Posts: 420 Central Ohio
Ledman_70
Central Ohio
Hey Charger, can you describe how to cover your old dash pad? I have upholstered chairs before, but the folded corners show. How you do heat the material to stretch it so it doesn't show? Thanks
Jeff Adams
64 426 Polara
