how is there oil in the intake #89608
07/16/08 09:27 PM
07/16/08 09:27 PM
sc
68spinnrunner Offline OP
sc
I have a 440-512 stroker motor, with less than 500 miles on the motor. Everything is either new or rebuilt, 10.5 to one pistons, 509 cam with 1.6 ratio crane rockers, with 915 closed chamber heads ported and polished new valves, guides, seals. With a six pack intake. I took the front carb off and noticed oil in the bottom of the intake but not alot. Is this normal on a new engine? I do not understand how oil would get there in the first place. Can you guys please give me some ideas on how to fix this? Thanks
Re: how is there oil in the intake [Re: 68spinnrunner] #89609
07/16/08 09:31 PM
07/16/08 09:31 PM
N
NITROUSN Offline
NITROUSN  Offline
N
What are you running for pcv and vents? Other than pcv issues possible intake leak into the valley sucking in oil.
Re: how is there oil in the intake [Re: NITROUSN] #89610
07/16/08 09:42 PM
07/16/08 09:42 PM
sc
sc
I thought I had a leaky intake so I resealed it, but it is still doing the same thing, I even used gaskets, but it would explain why it doesn't idle right.I use a pvc valve connected to the carb and a breather.
Re: how is there oil in the intake [Re: 68spinnrunner] #89611
07/16/08 10:02 PM
07/16/08 10:02 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Normally with intake gaskets leaking the oil is pulled directly into the head and not into the intake. Cap the pcv port and remove the valve and run it and see what happens. Maybe the valve is no good and its sucking excessively pulling oil into the plenum area of the intake.
Re: how is there oil in the intake [Re: NITROUSN] #89612
07/17/08 03:51 AM
07/17/08 03:51 AM
sc
sc
thanks man, that is something I have not thought about. I can't wait to try it.
Re: how is there oil in the intake [Re: 68spinnrunner] #89613
07/17/08 08:49 AM
07/17/08 08:49 AM
Eastern Ohio
mopowergtx Offline
mopowergtx  Offline
Eastern Ohio
Do you have a baffle plate on the inside of the valve cover under the pcv valve hole? You need one if you dont. All stock covers have them but aftermarket covers are hit and miss if they do or not. Alot of oil gets slung around in there when its running and you better have a baffle or your going to suck oil in through the pcv valve.
Re: how is there oil in the intake [Re: mopowergtx] #89614
07/17/08 09:25 AM
07/17/08 09:25 AM
Findlay
Ramman Offline
Ramman  Offline
Findlay
"Maybe the valve is no good and its sucking excessively pulling oil into the plenum area of the intake."
And this would be another reason it won't idle properly. Had the guts fall out of a P.C.V. valve one time and it wouldn't idle period. Caused a 3/8" vacuum leak and was a bear for my little mind to find. Swore the carb. or a intake valve had gone south.
