What primer under 2k ceramic epoxy? #895972
01/04/11 11:47 AM
01/04/11 11:47 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Does the Eastwood epoxy 2k require a primer? Should I apply over bare metal? Should i use DP90? Will the 2k epoxy lift an aerosol primer?
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger in original burgundy paint "Ribeye"
1968 Charger w/ 6.1L, TR-6060, 9"
1968 Roadrunner w/ 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
Re: What primer under 2k ceramic epoxy? [Re: 70B5Cuda] #895973
01/04/11 02:34 PM
01/04/11 02:34 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
i dont understand buying paint from eastwwod. everything they sell can be got locally.
Re: What primer under 2k ceramic epoxy? [Re: 05dakota] #895974
01/04/11 04:06 PM
01/04/11 04:06 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: What primer under 2k ceramic epoxy? [Re: 70B5Cuda] #895975
01/04/11 04:48 PM
01/04/11 04:48 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Does the Eastwood epoxy 2k require a primer? No but you should use an etching primer on bare metal.
Should I apply over bare metal? Some 2K primners say you can but I always use etching primer to make sure.
Should i use DP90? Great product
Will the 2k epoxy lift an aerosol primer? yep
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: What primer under 2k ceramic epoxy? [Re: 05dakota] #895976
01/04/11 05:30 PM
01/04/11 05:30 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
why would u prime under an epoxy primer?
I will be using the Eastwood 2k ceramic epoxy, which is not a primer.
Eastwood's suggested their rust encapsulator under the 2k ceramic epoxy.
