What primer under 2k ceramic epoxy?
#895972
01/04/11 11:47 AM
01/04/11 11:47 AM
Posts: 1,070 Newton, KS
70B5Cuda
Newton, KS
Does the Eastwood epoxy 2k require a primer? Should I apply over bare metal? Should i use DP90? Will the 2k epoxy lift an aerosol primer?
1970 Barracuda B5 6.1 Hemi/6 speed 1969 Charger survivor in R6 383/727-wrecked 12/24/18 1968 Charger in original burgundy paint "Ribeye" 1968 Charger w/ 6.1L, TR-6060, 9" 1968 Roadrunner w/ 6.1L/6 speed 2011 Dodge Ram w/ 6.7L
Re: What primer under 2k ceramic epoxy?
[Re: 70B5Cuda]
#895975
01/04/11 04:48 PM
01/04/11 04:48 PM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
Does the Eastwood epoxy 2k require a primer? No but you should use an etching primer on bare metal. Should I apply over bare metal? Some 2K primners say you can but I always use etching primer to make sure. Should i use DP90? Great product Will the 2k epoxy lift an aerosol primer? yep
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
