Rebuilding an TF-727 #895710
01/03/11 09:56 PM
01/03/11 09:56 PM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
Has anyone here that's not a transmission mechanic rebuilt a 727 trans? I have a big block 727 core correct for my car and I found a small block 727 newly rebuilt with HD parts and stage 2 shift kit for dirt cheap (a third the price of new).
How much of a challenge would it be to swap the guts? is it worth it?
I’m listening.
Re: Rebuilding an TF-727 [Re: Big Bad Bee] #895711
01/03/11 11:36 PM
01/03/11 11:36 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
about 5 yrs ago..i decided to rebuild my own trans ...got the ATSG and 727 video...never looked back.
the 727/904 are easy trans to rebuild.
Tony
70 AARCuda Vitamin C
Re: Rebuilding an TF-727 [Re: Big Bad Bee] #895712
01/03/11 11:44 PM
01/03/11 11:44 PM
md
W
wicked Offline
wicked  Offline
W
md
I've been through a few, get yourself an ATSG manual one of the better ones. Haynes manual has photos which can be helpful, but not as much tech. They are not difficult to do, but time consuming. There have been some subtle changes throughout the year spread so pumps can be case specific and the shafts and planetaries and such need to be kept together as there were some differences in the splined areas. The paperwork for the shift kit would be important if any case mods were made. clean is important, a piece of lint can jam a valve.
Re: Rebuilding an TF-727 [Re: Big Bad Bee] #895713
01/04/11 12:34 AM
01/04/11 12:34 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
It'll be a piece of cake, get the manual , check the end play on both trans. before you take them a part , record and compare to the new one after reassembly .
Re: Rebuilding an TF-727 [Re: 70AARcuda] #895714
01/04/11 12:54 AM
01/04/11 12:54 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
I have done so many, I can almost do them blindfolded
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Rebuilding an TF-727 [Re: 69L78Nova] #895715
01/04/11 01:29 AM
01/04/11 01:29 AM
Newton, KS
70B5Cuda Offline
70B5Cuda  Offline
Newton, KS
But can you do it blindfolded while hanging upside down in your closet?
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger in original burgundy paint "Ribeye"
1968 Charger w/ 6.1L, TR-6060, 9"
1968 Roadrunner w/ 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
Re: Rebuilding an TF-727 [Re: Big Bad Bee] #895716
01/04/11 02:09 AM
01/04/11 02:09 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
you can do it Lindy
as said, get the manuals! and remember to keep everything very clean.
Re: Rebuilding an TF-727 [Re: nomore65BelvJim] #895717
01/04/11 06:14 AM
01/04/11 06:14 AM
Spokane Valley, WA
Spokane Valley, WA
That's encouraging! I'm gonna go for it. If I buy new, what kit should I buy, considering its goingbehind a 500 HP 451 stroker? what is an ATSG? Should I go manual valve body? Is There a way to customize the b body shifter so that it works like a slapstik? I hate the idea of gingerly pushing through the shifts.
I’m listening.
Re: Rebuilding an TF-727 [Re: Big Bad Bee] #895718
01/04/11 07:11 AM
01/04/11 07:11 AM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
My first attempt at a trans was a 727 using the B&M $250 kit. It has a good step by step book in it with options on how to build it to suit your needs. I tried it, and it is still in the car to this day after hundreds of passes down into the 10's and some high speed 90 mile long open road races doing over 140 mph. It is very easy if you are patient.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: Rebuilding an TF-727 [Re: 67Charger] #895719
01/04/11 09:48 AM
01/04/11 09:48 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Shift kits are relatively easy. Anything requireing pulling the front pump will need a slide hammer (preferably two but I did it with one). Deeper in there are a few things that are best to remove with drivers made to fit. That's where it can be a real pain. My impression is most folks either leave those parts or (like I did) find someone who has the tools.
I made a stand out of angle iron to hold the case while working on it. Not critical, but something to consider.
Swapping guts may or may not make sense - depends on the years and exactly which guts. The Monroe book on 727 transmissions covers the year to year variations etc. Well worth buying for someone considering swapping parts.
Re: Rebuilding an TF-727 [Re: Mattax] #895720
01/04/11 10:18 AM
01/04/11 10:18 AM
Unfortunately back in New York
N
Nukechargerboy Offline
N
I 2nd that book. Very informative and it has a hipo section for tweaking. Hundreds of pictures in a clear and concise method, you really can't screw up. When I rebuilt mine I was greatly impressed by the previous rebuilder, as I have had this tranny for 25 years and haven't put it into a car yet. I bought the book and did a refresh on the internals. I didn't change any bushings but that isn't really that hard. It's a good time to strenghten your trans for later mods, that's why I went through mine, maybe one day i'll get that stroker.....
Re: Rebuilding an TF-727 [Re: Big Bad Bee] #895721
01/04/11 12:47 PM
01/04/11 12:47 PM
Under My Car
Mopar_Country Offline
Under My Car
Re: Rebuilding an TF-727 [Re: 70B5Cuda] #895722
01/04/11 01:11 PM
01/04/11 01:11 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Not hanging in a closet, but I rebuilt an 833 some years back while blindfolded, hanging upside down from a pine tree
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: Rebuilding an TF-727 [Re: Mopar_Country] #895723
01/04/11 01:21 PM
01/04/11 01:21 PM
Spokane Valley, WA
Spokane Valley, WA
what is an ATSG?
http://www.700r4l60e.com/store/product.php?productid=229
Perfect. Thank you.
So what's the best way to support trans while rebuilding? build a bench jig? I was wondering if an engine stand would work but thought it would block the nose gear too much.
I’m listening.
Re: Rebuilding an TF-727 [Re: Big Bad Bee] #895724
01/04/11 01:48 PM
01/04/11 01:48 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Here are some kits that are reasonably priced.
http://www.bulkpart.com/Merchant2/mercha...;Category_Code=
http://www.northernautoparts.com/ProductModelDetail.cfm?ProductModelId=9102
Get a deluxe kit and you should be pretty set.
Re: Rebuilding an TF-727 [Re: Big Bad Bee] #895725
01/04/11 02:59 PM
01/04/11 02:59 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
I used a piece of particle board, with a hole in it, overtop of a trashcan.
You really only need it verticle for when you load the tailshaft and overrunning clutch. After that, I made a fixture, out of 2X4's, to flip the trans on its back and load the planetaries and clutches. There's 2 ears on each side of the trans, towards the rear, that make a good place for a "stand".
A factory service manual is actually very good to start with. The book by Munroe will answer any and all questions thereafter.
Re: Rebuilding an TF-727 [Re: Dean_Kuzluzski] #895726
01/04/11 05:53 PM
01/04/11 05:53 PM
RobX4406 Offline
RobX4406  Offline
B Body Bob had the best IIRC
A wheelbarrow stood up with the trans between the handles... Priceless Wish I had a pic of it.
Re: Rebuilding an TF-727 [Re: RobX4406] #895727
01/04/11 06:42 PM
01/04/11 06:42 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Timely . . . Just before christmas, I was at my buddies place in Spokane, and we rebuilt a small block 727 . . . he is the seasoned vet, and I had NEVER pulled a tranny apart before. Course he made it look easy, but realistically, having the book, and the tool for holding the pistons down on the springs in order to get the snap rings in, made everything way easy !!!
I figure you just take your time, pull it apart, inspect everything and replace your steels & clutch discs & thrust bearings/washers and your seals, and you will be good to go !!!
Course my buddy has a hot tank washer unit - man it works great !!! So the case was like brand new again !!! . . .never used a slide hammer to pull the front pump out of the case, took the guts out and then just "tapped" the front pump out using a hammer and extension . . . .
After doing this one tranny, with his help, I would certainly say, go for it !!! . . .
Cheers
Mark
Re: Rebuilding an TF-727 [Re: a12rag] #895728
01/04/11 07:52 PM
01/04/11 07:52 PM
Missouri
bb74swngr Offline
mopar addict
bb74swngr  Offline
mopar addict
Missouri
It's been a few years since I did a rebuild and have only done a few. It seems to me that all of the pumps I pulled had additional threaded holes that I screwed bolts into to "push" the pump out. Removed all of the bolts holding the pump in and then threaded/ran the bolts in to remove the pump. Didn't need a slide puller.
Russ...
BigBlock 74 Swinger
Re: Rebuilding an TF-727 [Re: bb74swngr] #895729
01/04/11 08:19 PM
01/04/11 08:19 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I used two pieces of threaded rod and a chunk of angle iron with the slide hammer and worked very well. Used 2x4 s and a piece of plywood with a hole cut in it to hold the case. Just keep it clean and keep track of where everything came from and you should have no problem.
