Rebuilding an TF-727
#895710
01/03/11 09:56 PM
01/03/11 09:56 PM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
Has anyone here that's not a transmission mechanic rebuilt a 727 trans? I have a big block 727 core correct for my car and I found a small block 727 newly rebuilt with HD parts and stage 2 shift kit for dirt cheap (a third the price of new).
How much of a challenge would it be to swap the guts? is it worth it?
I’m listening.
Re: Rebuilding an TF-727
[Re: Big Bad Bee]
#895711
01/03/11 11:36 PM
01/03/11 11:36 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
about 5 yrs ago..i decided to rebuild my own trans ...got the ATSG and 727 video...never looked back.
the 727/904 are easy trans to rebuild.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 69L78Nova]
#895715
01/04/11 01:29 AM
01/04/11 01:29 AM
Posts: 1,064 Newton, KS
70B5Cuda
Newton, KS
But can you do it blindfolded while hanging upside down in your closet?
1970 Barracuda B5 6.1 Hemi/6 speed 1969 Charger survivor in R6 383/727-wrecked 12/24/18 1968 Charger in original burgundy paint "Ribeye" 1968 Charger w/ 6.1L, TR-6060, 9" 1968 Roadrunner w/ 6.1L/6 speed 2011 Dodge Ram w/ 6.7L
[Re: nomore65BelvJim]
#895717
01/04/11 06:14 AM
01/04/11 06:14 AM
Big Bad Bee
Spokane Valley, WA
That's encouraging! I'm gonna go for it. If I buy new, what kit should I buy, considering its goingbehind a 500 HP 451 stroker? what is an ATSG? Should I go manual valve body? Is There a way to customize the b body shifter so that it works like a slapstik? I hate the idea of gingerly pushing through the shifts.
I’m listening.
[Re: Big Bad Bee]
#895718
01/04/11 07:11 AM
01/04/11 07:11 AM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
My first attempt at a trans was a 727 using the B&M $250 kit. It has a good step by step book in it with options on how to build it to suit your needs. I tried it, and it is still in the car to this day after hundreds of passes down into the 10's and some high speed 90 mile long open road races doing over 140 mph. It is very easy if you are patient.
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: 67Charger]
#895719
01/04/11 09:48 AM
01/04/11 09:48 AM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Shift kits are relatively easy. Anything requireing pulling the front pump will need a slide hammer (preferably two but I did it with one). Deeper in there are a few things that are best to remove with drivers made to fit. That's where it can be a real pain. My impression is most folks either leave those parts or (like I did) find someone who has the tools. I made a stand out of angle iron to hold the case while working on it. Not critical, but something to consider. Swapping guts may or may not make sense - depends on the years and exactly which guts. The Monroe book on 727 transmissions covers the year to year variations etc. Well worth buying for someone considering swapping parts.
[Re: RobX4406]
#895727
01/04/11 06:42 PM
01/04/11 06:42 PM
Posts: 2,918 Calgary, Alberta Canada
a12rag
Timely . . . Just before christmas, I was at my buddies place in Spokane, and we rebuilt a small block 727 . . . he is the seasoned vet, and I had NEVER pulled a tranny apart before. Course he made it look easy, but realistically, having the book, and the tool for holding the pistons down on the springs in order to get the snap rings in, made everything way easy !!!
I figure you just take your time, pull it apart, inspect everything and replace your steels & clutch discs & thrust bearings/washers and your seals, and you will be good to go !!!
Course my buddy has a hot tank washer unit - man it works great !!! So the case was like brand new again !!! . . .never used a slide hammer to pull the front pump out of the case, took the guts out and then just "tapped" the front pump out using a hammer and extension . . . .
After doing this one tranny, with his help, I would certainly say, go for it !!! . . .
Cheers
Mark
[Re: a12rag]
#895728
01/04/11 07:52 PM
01/04/11 07:52 PM
Posts: 799 Missouri
bb74swngr
mopar addict
mopar addict
Missouri
It's been a few years since I did a rebuild and have only done a few. It seems to me that all of the pumps I pulled had additional threaded holes that I screwed bolts into to "push" the pump out. Removed all of the bolts holding the pump in and then threaded/ran the bolts in to remove the pump. Didn't need a slide puller. Russ...
BigBlock 74 Swinger
