Trunk floor install? #895494
01/03/11 02:32 PM
01/03/11 02:32 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
What is the best way to install a one piece trunk floor. 1970 Cuda convertible. Do you have to take the quarter and the wheel houses out or can you get around the wheel house. I don't want to take the tail panel off if i don't have to. Any body with some experience good or bad would be a help.
Thanks Brian
Re: Trunk floor install? [Re: 340swing] #895495
01/06/11 10:32 PM
01/06/11 10:32 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
anybody ever replace a trunk floor?
Re: Trunk floor install? [Re: 340swing] #895496
01/06/11 10:39 PM
01/06/11 10:39 PM
Fairview Tennessee
SV_MOPARS Offline
SV_MOPARS  Offline
Fairview Tennessee
i have never done a 1 piece, but if i'm not mistaken you have to take the tailight panel out, which to me is not worth it, i would just do the 2 piece, so what if you end up with a seam down the center that is really only visable from the top and you will have to pull back the trunk mat to see it, if you do a nice job welding the seam it will hardly be noticable, i have done them all this way. just my
Re: Trunk floor install? [Re: SV_MOPARS] #895497
01/06/11 10:51 PM
01/06/11 10:51 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
Thanks for the reply. I have the one piece floor already. Both quarters have to be replaced. I thought with one off I would be able to get it in. But it's a convertible and all the brackets are welded to the top of the wheel houses. The tail panel looks like the best way but I really didn't want to take it off. I was hoping somebody had a trick or could tell me how they have done it.
Re: Trunk floor install? [Re: 340swing] #895498
01/06/11 11:31 PM
01/06/11 11:31 PM
Eastern,NC
68GTS383 Offline
68GTS383  Offline
Eastern,NC
I have installed the two piece trunk pan in a 70 GTX and it was pretty easy. I am in the process of installing a one piece in a 69 Charger. It is impossible to do with out removing the tail panel. The one piece pan is too long to go in thru a removed 1/4 panel.
Re: Trunk floor install? [Re: 68GTS383] #895499
01/06/11 11:37 PM
01/06/11 11:37 PM
western PA
mopar4ya Offline
mopar4ya  Offline
western PA
I know guys have done the one piece in a hard top. I believe you have to bend a corner of the new pan. Maybe someone that has done this will chime in.
Dan.
Re: Trunk floor install? [Re: 68GTS383] #895500
01/06/11 11:40 PM
01/06/11 11:40 PM
Ct, Oxford
340swing Offline OP
340swing  Offline OP
Ct, Oxford
Thats what the cuda looks like to. If I have to i will remove the tail panel. It seems like the only option at this time.
Re: Trunk floor install? [Re: 340swing] #895501
01/07/11 12:09 AM
01/07/11 12:09 AM
Eastern,NC
68GTS383 Offline
68GTS383  Offline
Eastern,NC
Have you considered splitting the trunk panel and welding a strip to over lap the split.This can be done on the underside. It is a lot of work to remove/replace a tail panel.Probably cheaper to sell the one piece and buy a two piece.Unless you are building a show car the two piece should be fine.Can't be seen with the trunk lid closed.
Re: Trunk floor install? [Re: 68GTS383] #895502
01/07/11 01:43 AM
01/07/11 01:43 AM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
I replaced mine in my 70 barracuda with a AMD 1 piece pan. I also had to replace the dutchman panel. It still needed to be wedged in to get it into the trunk. I have also heard of people removing the braces behind the reae seat to get the in.
My Monster are real!
Living within your means makes life pretty easy.
