E Body Rear Rim Back Spacing Help #895463
01/03/11 01:54 PM
01/03/11 01:54 PM
FT Campbell, KY / Clarksville,...
The Cuda Guy Offline OP
Friends,
Wanted to check in and see if a 15x10" rim with a back space of 3.5 will fit in the stock wheel rear wells of a E Body (73 Cuda). I have come accross a killer deal on some old school polished alum slots and wanted to check here before pulling the trigger on them.
Have a D60 that has not been cut to size yet, looking at going with a b-body legenth or shorter if needed, if that helps? Looking at some SS type springs for the rear susp.
If the answer is no with a stock set up what can be done to make them fit eg. cut dana shorter and move springs in further? I do not want to tub or mini tub this car. Want the wheel to resied under inside the stock wells and within the rear qtr opening and not to extend outside the qtr lip. Thanks guys for any input you have.
Don
Street/Strip 73 Barracuda
Re: E Body Rear Rim Back Spacing Help [Re: The Cuda Guy] #895464
01/03/11 02:03 PM
01/03/11 02:03 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
They won't fit the stock rear end etc. Here's a small bit of related info. You can find lots more using the search function.
https://board.moparts.org/ubbthreads/show...e=3#Post6379696
Re: E Body Rear Rim Back Spacing Help [Re: jbc426] #895465
01/03/11 02:07 PM
01/03/11 02:07 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
It don't matter how big of a tire you stuff in there your car is a dud and I'm dragging you down the 660' at Carlisle
Mopar Performance
Re: E Body Rear Rim Back Spacing Help [Re: The Cuda Guy] #895466
01/03/11 02:09 PM
01/03/11 02:09 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We have 10 inch rims on ours, back spacing is 6.5 inch. We have the 1 inch inboard spring kit and stock width Dana. Tyre is very close to the fender lip (29.5 x 10.5 slick) we had to re-arch the springs to get them to fit, which brought upon another set of problems.
I'd guess, since our car is a Challenger, that dependant on tyre they'll have too much outset and won't fit but I don't know for sure
Re: E Body Rear Rim Back Spacing Help [Re: jbc426] #895467
01/03/11 02:10 PM
01/03/11 02:10 PM
Here we go with the search button bit, what if I told you I did use it and it didnt come up with the info I was looking for???
Next time just dont reply to one of my threads. I dont need that type of help. Thanks but no thanks.
Don
Re: E Body Rear Rim Back Spacing Help [Re: moparniac] #895468
01/03/11 02:38 PM
01/03/11 02:38 PM
Just show up with a car this time and we will see who will win.... LOL!!!
Don
Re: E Body Rear Rim Back Spacing Help [Re: The Cuda Guy] #895469
01/03/11 03:08 PM
01/03/11 03:08 PM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
Will not fit, will need to move springs in and shorten rear.
Re: E Body Rear Rim Back Spacing Help [Re: jvcuda] #895470
01/03/11 03:32 PM
01/03/11 03:32 PM
Thanks.
Will there be any modification of the wheel wells needed or just a spring relocation and shorter legenth Dana? I have a buddy who fit 15x10 with 5in bs in a Challenger with a 54-5/8" Dana and a spring relo. So would it just be a matter of measureing the difference in the offset and cutting the housing to spec? Thanks.
Don
Don
Re: E Body Rear Rim Back Spacing Help [Re: The Cuda Guy] #895471
01/03/11 04:06 PM
01/03/11 04:06 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I already have you the doc dif relocation kits for 5 inch back space, And started getting prepaired for you to get a chrome moly cage hand built in may. To run with Jsson, I either need you a lot lighter or more hp
Re: E Body Rear Rim Back Spacing Help [Re: Mopar-Al] #895472
01/03/11 04:18 PM
01/03/11 04:18 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
don I know your budget is tight any prolly have a great deal on wheels but its best to just them go! good deals come around so just be patient!
15*10 setups with 5" backspace will give you alot of options for different wheels especially when good deals come around
Mopar Performance
Re: E Body Rear Rim Back Spacing Help [Re: The Cuda Guy] #895473
01/03/11 06:03 PM
01/03/11 06:03 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I'd believe it.
Re: E Body Rear Rim Back Spacing Help [Re: jbc426] #895474
01/03/11 06:10 PM
01/03/11 06:10 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I'd believe it.
Me to...but try the "google custom search" box at the top of the page...it's easier to use.
Re: E Body Rear Rim Back Spacing Help [Re: jbc426] #895475
01/03/11 06:16 PM
01/03/11 06:16 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
i fit a 315/60-15 drag radial in a stock wheelwell but its VERY tight. i made all my own offset hangers to bolt in the factory locations (stock suspension BS) wheels are 15x10 with 4 inch backspace with a 5/16 spacer. could probably use a 3.5 but may be a little close to the inner. housing is 57 1/8 axle flange to axle flange
