E Body Rear Rim Back Spacing Help
#895463
01/03/11 01:54 PM
01/03/11 01:54 PM
Posts: 376 FT Campbell, KY / Clarksville,...
The Cuda Guy
Friends,
Wanted to check in and see if a 15x10" rim with a back space of 3.5 will fit in the stock wheel rear wells of a E Body (73 Cuda). I have come accross a killer deal on some old school polished alum slots and wanted to check here before pulling the trigger on them.
Have a D60 that has not been cut to size yet, looking at going with a b-body legenth or shorter if needed, if that helps? Looking at some SS type springs for the rear susp.
If the answer is no with a stock set up what can be done to make them fit eg. cut dana shorter and move springs in further? I do not want to tub or mini tub this car. Want the wheel to resied under inside the stock wells and within the rear qtr opening and not to extend outside the qtr lip. Thanks guys for any input you have.
Don
Street/Strip 73 Barracuda
Re: E Body Rear Rim Back Spacing Help
[Re: The Cuda Guy]
#895464
01/03/11 02:03 PM
01/03/11 02:03 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
They won't fit the stock rear end etc. Here's a small bit of related info. You can find lots more using the search function. https://board.moparts.org/ubbthreads/show...e=3#Post6379696
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: The Cuda Guy]
#895466
01/03/11 02:09 PM
01/03/11 02:09 PM
Posts: 2,924 A shed in England
Tig
A shed in England
We have 10 inch rims on ours, back spacing is 6.5 inch. We have the 1 inch inboard spring kit and stock width Dana. Tyre is very close to the fender lip (29.5 x 10.5 slick) we had to re-arch the springs to get them to fit, which brought upon another set of problems. I'd guess, since our car is a Challenger, that dependant on tyre they'll have too much outset and won't fit but I don't know for sure
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: jbc426]
#895474
01/03/11 06:10 PM
01/03/11 06:10 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
Here we go with the search button bit, what if I told you I did use it and it didnt come up with the info I was looking for???
I'd believe it.
Me to...but try the "google custom search" box at the top of the page...it's easier to use.
