Procedure to Paint exhaust manifolds on engine #895027
01/02/11 10:51 PM
01/02/11 10:51 PM
Ont, Canada
gygeneral Offline OP
Ont, Canada
I want to paint the manifolds orange when the engine gets painted. My question is, do you paint the manifolds cast grey before they get painted with the orange paint or do you just clean them, bead blast them and install as is, then apply the engine paint.
Re: Procedure to Paint exhaust manifolds on engine [Re: gygeneral] #895028
01/02/11 10:56 PM
01/02/11 10:56 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
I would have them ceramic coated cast grey first, then mount them and paint the engine orange. That way the orange paint will burn off and the manifolds will NEVER rust.
I've done about 5 sets this way now with good results. On my car I just went with the orange paint and now they look like rusty crap.
CHECK OUT MY NEW WEB SITE !
Re: Procedure to Paint exhaust manifolds on engine [Re: anlauto] #895029
01/02/11 11:14 PM
01/02/11 11:14 PM
Ont, Canada
Ont, Canada
Thanks Alan, where would you get this done in Ontario. Do you have any pictures?
Re: Procedure to Paint exhaust manifolds on engine [Re: gygeneral] #895030
01/02/11 11:17 PM
01/02/11 11:17 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
I just paint them on the engine.....That was Ma's procedure.
Re: Procedure to Paint exhaust manifolds on engine [Re: gygeneral] #895031
01/03/11 02:03 AM
01/03/11 02:03 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
IIRC, Alan uses Fireball coatings in Ontario 519 833 2628
Re: Procedure to Paint exhaust manifolds on engine [Re: DAYCLONA] #895032
01/03/11 08:51 AM
01/03/11 08:51 AM
anlauto Offline
anlauto  Offline
My Mom has never done any, but Mike is correct...not sure how...but I use Fireball coatings in Erin ON. Price is $225.00 plus tax and they sandblast them.
www.fireballcoatings.com
I have a 340 in the garage that I can take pictures of later today...
Re: Procedure to Paint exhaust manifolds on engine [Re: DAYCLONA] #895033
01/03/11 09:12 AM
01/03/11 09:12 AM
Cleveland, OH
TWS Offline
TWS  Offline
Cleveland, OH
Any recommended ceramic coating companies here in the states?
Re: Procedure to Paint exhaust manifolds on engine [Re: TWS] #895034
01/03/11 09:46 AM
01/03/11 09:46 AM
Fort Workin Tx
Day2Runner Offline
Day2Runner  Offline
Fort Workin Tx
can they be ceramic coated in orange ??
Re: Procedure to Paint exhaust manifolds on engine [Re: TWS] #895035
01/03/11 09:46 AM
01/03/11 09:46 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Tim, my customer had his Hemi manifolds coated.I don't remember if they were jet hot coated or ceramic coated though
He is out of town till late tomorrow night.
I'll ask who and where when I talk to him , probably wednesday afternoon sometime
Re: Procedure to Paint exhaust manifolds on engine [Re: anlauto] #895036
01/03/11 11:01 AM
01/03/11 11:01 AM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Maybe paint them with that case of Stainless Steel paint....
Re: Procedure to Paint exhaust manifolds on engine [Re: FJ5_Fish] #895037
01/03/11 11:56 AM
01/03/11 11:56 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
does the ceramic coating or jet hot coating drop the under hood temp a lot?
Re: Procedure to Paint exhaust manifolds on engine [Re: ademon] #895038
01/03/11 10:31 PM
01/03/11 10:31 PM
Ont, Canada
Ont, Canada
Thanks Alan, I will give them a call.
By the way, do you have to remove the heat riser valve or do they coat that also.
Manythanks Norm
Re: Procedure to Paint exhaust manifolds on engine [Re: gygeneral] #895039
01/03/11 10:59 PM
01/03/11 10:59 PM
anlauto Offline
anlauto  Offline
You might want to remove it first. The coating may prevent it from working...I have never sent in manifolds with the heat riser....
Oh dam...I fogot to take pictures today...sorry..
Re: Procedure to Paint exhaust manifolds on engine [Re: gygeneral] #895040
01/04/11 09:28 PM
01/04/11 09:28 PM
anlauto Offline
anlauto  Offline
Here's some pictures.
DISCLAIMER: I'm not saying this is 100% correct...
Re: Procedure to Paint exhaust manifolds on engine [Re: anlauto] #895041
01/04/11 09:31 PM
01/04/11 09:31 PM
anlauto Offline
anlauto  Offline
...and the other side...
This is the way the customer wanted it....The shield was painted with BBQ paint first, not sure how long that will last.
I paint the motor first with a couple of good coats, mount the manifolds then give the motor one last coat
DISCLAIMER: I'm not saying this is 100% correct,
Re: Procedure to Paint exhaust manifolds on engine [Re: anlauto] #895042
01/04/11 10:32 PM
01/04/11 10:32 PM
Wilmington, NC
donbarnes Offline
Not THAT Don Barnes!!
donbarnes  Offline
Wilmington, NC
If you get past the original cost, Jet-Hot or similar ceramic is by far the way to go , and they come in all different colors. Anything that says "paint" on it will look like crap after a while, even the so called manifold paints like POR...
