what da heck? #893998
01/01/11 08:26 PM
01/01/11 08:26 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
this has got me stumpped.pulled the motor out of my street car sent the heads to Dwayne,gotem back witha a new cam and got it all together and mounted to my run stand.still same dizzy but a diff 6AL would not run good finally the box went poof,but i had a brand new spare,same dang thing.so several people including Dwayne said switch the wires, from the factory they could be wired wrong,BINGO it fired right up.now fast forward.motors installed go to fire itNO DICE,switch the wires and bingo it runs great.now after all that heres my question,it has to be the wires on the dizzy but how did it change? i never even removed the cap or plug wires and the box in the car is thesame box ive had for seven years and it always pluged in right.
Re: what da heck? [Re: bonefish] #893999
01/01/11 08:45 PM
01/01/11 08:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A difference in timing... my understanding is the
dist wires... one way it senses on the leading edge,
wire it the other way it senses the trailing edge
so if the timing was different it wanted to fire off
way late
Re: what da heck? [Re: bonefish] #894000
01/01/11 08:45 PM
01/01/11 08:45 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Reading that whole situation as one run-on sentence made my brain explode!
Re: what da heck? [Re: Commando1] #894001
01/01/11 08:53 PM
01/01/11 08:53 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Wrong, there's periods in there, just no capitals at the beginning of the sentences. That's the way that goes. at least it's not a text message..
Re: what da heck? [Re: Commando1] #894002
01/01/11 08:56 PM
01/01/11 08:56 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...There's 7 periods ..."sandwiched" in there.
Re: what da heck? [Re: thehemikid] #894003
01/01/11 09:44 PM
01/01/11 09:44 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
you prepies with your high skool edjamacation can KISS MY BUTT..... theres some caps and periods for ya.
Re: what da heck? [Re: bonefish] #894004
01/01/11 10:08 PM
01/01/11 10:08 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i think someones been at the beer frig too long.
Re: what da heck? [Re: rebel] #894005
01/01/11 11:00 PM
01/01/11 11:00 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
You guys are funny
Re: what da heck? [Re: emarine01] #894006
01/01/11 11:17 PM
01/01/11 11:17 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Any new wire harness between box and distributor...?? I know this is a common problem with MSD components. They need to look hard at their employees' eye tests, SOMEONE down there is 'color blind'!!!
I have seen this numerous times,,took alot of 'heat' from people who insist that it makes NO difference,,,,but,, more are finding out it DOES!
If you like drag racing, support your local track.
Re: what da heck? [Re: CHAPPER] #894007
01/01/11 11:23 PM
01/01/11 11:23 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
this is exactly the same as it has been.all i did was freshen the motor and put it back in.
Re: what da heck? [Re: CHAPPER] #894008
01/01/11 11:24 PM
01/01/11 11:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Very true and they say its not wrong.... I have
had to change 1 of my dist... now days if it dont
act right thats the FIRST place I look
Re: what da heck? [Re: MR_P_BODY] #894009
01/01/11 11:31 PM
01/01/11 11:31 PM
Q
Quicktree Offline
Quicktree  Offline
Q
the chinese putting these things together must be color blind these days.
Re: what da heck? [Re: MR_P_BODY] #894010
01/01/11 11:31 PM
01/01/11 11:31 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
i understand about the factory wires being backwards.but this has been runnin 7 years hooked up with the stock connectors.i had to shave the corners of the male end to reverse the wires.
Re: what da heck? [Re: bonefish] #894011
01/01/11 11:40 PM
01/01/11 11:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
LOL... most of us just cut the wires swap them and
use solder and shrink tubing.... because NOW you can
put it in in either direction
Re: what da heck? [Re: MR_P_BODY] #894012
01/01/11 11:47 PM
01/01/11 11:47 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
yeh i guess im just lazy,30 seconds with a exacto knife and slide it in,nice tight fit,plus if it fixes its self i can just turn it back over
