Tire sizes for a 70 Roadrunner #892824
12/31/10 07:24 PM
12/31/10 07:24 PM
Texas
70Runnerdude Offline OP
Texas
Just wondering what would be the best tire size to run on a 70 Roadrunner with factory 15 x 7 Rallye wheels ? I would like to have as much tire as I can with out rubbing them.
Re: Tire sizes for a 70 Roadrunner [Re: 70Runnerdude] #892825
12/31/10 08:04 PM
12/31/10 08:04 PM
very Southern Indiana
skullbucket Offline
skullbucket  Offline
225/70/15 white letter BFGs, just like everybody else, me included!
Everything else is too short.
Re: Tire sizes for a 70 Roadrunner [Re: skullbucket] #892826
12/31/10 08:39 PM
12/31/10 08:39 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
This is 235/60-15 in front...
295/50-15 in the rear...
Re: Tire sizes for a 70 Roadrunner [Re: 1_WILD_RT] #892827
12/31/10 09:38 PM
12/31/10 09:38 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
A '70 Road Runner with 15x7" wheels would've had F60-15s from the factory.
Modern equivalent would be 235/60/15s all around. 245/60/15s will fit no problem.
If you go to 255/60/15s all around the front starts getting close, maybe too close depending on your ride height.
245/60/15s on the front & 275/60/15s on the rear would work for me!!
IMO most 70 series tires on 7" wheels don't look right (narrow tire/wide wheel)
Re: Tire sizes for a 70 Roadrunner [Re: 6bblgt] #892828
12/31/10 11:26 PM
12/31/10 11:26 PM
skullbucket Offline
skullbucket  Offline
A 215 is for a 6 inch rim and a 225/70 is for a 7 inch rim.
235s are too short unless you like the light space between the tire and rim look, or rubbing every speed bump in the parking lot???
I would think a 275 or a 295 would be a little much for a 7 inch rim???
My car looks just fine with 225/70s on a 15X7 inch rim, think, think not???
Re: Tire sizes for a 70 Roadrunner [Re: 1_WILD_RT] #892829
12/31/10 11:37 PM
12/31/10 11:37 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
as long as the ratio has a 70, or a 60, go as wide as you can, without the cartoon looking "balloon" effect taking place. 235 on front of my ride, and 275 on the rear, still looks right.
Re: Tire sizes for a 70 Roadrunner [Re: skullbucket] #892830
01/01/11 01:05 AM
01/01/11 01:05 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Tire manufacturers have approved wheel sizes for particular size tires, there are no hard & fast absolutes. I have a Goodyear tire engineering data brochure from '86 that has plenty of dimensions/numbers in it to aid in choosing the tires for your ride.
Under Eagle GT - they recommend:
215/70HR15 5.5"-7.5" wheels (tire has 6.64" of tread)
225/70HR15 6.0"-8.0" wheels (tire has 6.86" of tread)
I prefer more tread than wheel width, it helps to give radials the "squared off" look the Polyglas & Wide Oval tires had.
If one is going for the "High & Mighty" look, I will agree a 60 series tire on the front doesn't help the "look". "High & Mighty" needs more of a big & little combination of tires & wheels. IMO with tall & skinny tires on the front, the rears still need to be as tall or taller than the fronts.
275s are pushing the limit on 7" wheels - they won't wear evenly but they work and look great & if you look at the Road Runner pic above the 295/50/15 rears are on 8" if not wider wheels.
You have to be happy with your car, I'd be happy with more tire, especially on the rear. Here's a pic of my brother's '68 GTX with 225/70/15s on 15x6.0 Spyder Wheels. It works but isn't ideal, the "old school" wheels are the limiting factor.
Re: Tire sizes for a 70 Roadrunner [Re: 70Runnerdude] #892831
01/01/11 01:12 AM
01/01/11 01:12 AM
kentucky
roadrunner7020 Offline
kentucky
I dunno on a 7 inch rim On the rear on the rear I like a 275/60 that's what I run but on an 8 inch wheel
