Small Block Intake Gasket Questions... #89115
07/15/08 07:28 PM
07/15/08 07:28 PM
Indiana
W5Duster436 Offline OP
Indiana
I am getting ready to put my intake back on my 340 and won't be using the front/rear cork gaskets so should I cut off the head gasket tabs beforehand or just push them down and use silicone over them? I already had it running but it was leaking and I don't want it to leak again.
Also, the M1 intake I have is machined for a spreadbore type carb. Since I am running a holley 4150 carb do I use the 4150 type gasket or the spreadbore gasket to match the intake regardless? Enquiring mind wants to know..
'70 Duster - SDSS 436 W5 4spd (Gone)
'71 Dodge D100
'70 Dodge W100
Re: Small Block Intake Gasket Questions... [Re: W5Duster436] #89116
07/15/08 08:07 PM
07/15/08 08:07 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I always pushed the tabs down but make sure you get plenty of sealer around the tabs.
Re: Small Block Intake Gasket Questions... [Re: W5Duster436] #89117
07/15/08 09:36 PM
07/15/08 09:36 PM
use one of these
Re: Small Block Intake Gasket Questions... [Re: W5Duster436] #89118
07/15/08 09:51 PM
07/15/08 09:51 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Edelbrock also make that carb flange plate.
I know it's a stocking item at the local parts america/kragen outlet.
Re: Small Block Intake Gasket Questions... [Re: RobX4406] #89119
07/15/08 10:07 PM
07/15/08 10:07 PM
Indiana
Indiana
I actually have some steel plates that were isolators I guess that look just like that plate except thinner and square on both ends. I assume this has the spreadbore on one side?
I had my carb on there already with just the square gasket and it seemed to work fine but I just wasn't sure which gasket to use or if using the square gasket on that spreadbore would cause the fuel/air to not disperse correctly.
Re: Small Block Intake Gasket Questions... [Re: W5Duster436] #89120
07/15/08 11:24 PM
07/15/08 11:24 PM
no it's a flat plate the same on each side. What you might be seeing is in the (4) corners that is just a square bore gasket underneath that is included with the Erson pkg.
