Re: stock juice roller lifters
[Re: MIKES_DUSTER]
#890465
12/28/10 07:06 PM
12/28/10 07:06 PM
Posts: 3,422 Toronto
mshred
Toronto
Like I said in my other post,for $269.99?? Its a piece of mind to buy new ones. Im running a .570 with 1.6 rockers with no problems.
not sure what other post you are talking about
Im talking about hydraulic roller lifters, not solid rollers btw in case i wasnt clear
anyways, back to the original question...would the stock ones be ok? I cant see much difference between them and aftermarket ones except for price
[Re: Streetwize]
#890468
12/28/10 11:06 PM
12/28/10 11:06 PM
mshred
Toronto
I reused a set of OEM HR lifters in my 88 318/341 mini stroker block. No issues at all on a 236/240 @.050 HR...probably use them again when I find another home for this motor.
good to hear...anybody else in the same situation?
[Re: mshred]
#890469
12/29/10 03:29 PM
12/29/10 03:29 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
you're fine using them and then tend to be quieter than performacne variants. Make sure the preload is right, and you're good to go.
[Re: moper]
#890470
01/01/11 11:56 AM
01/01/11 11:56 AM
Posts: 15,487 Florida
scratchnfotraction
I run a set of used stock 1990 roller lifters in my 88 318 with a lunati roller cam..not big but .485 lift been 6200rpms and no valve float with the comp 901-16 springs used all the stock roller gear and hardware from the 90 engine didnt keep them in order as they dont need a break in from what I understand oh, and my 88 318 oils thru the block/heads to the rockers along with the oil tru roller lifters and hollow rods so it oiling both ways the stock 90 318 was this way also thats one step closer to a magnum head swap for a pre-mag hybred they are pushing over 200,000 miles now,,
[Re: dvw]
#890474
02/06/12 01:35 AM
02/06/12 01:35 AM
Posts: 1,086 Baton Rouge, La.
StandOnIt
Baton Rouge, La.
My 98' 5.9 magnum has a cam motion .580 at the valve hyd roller with the stock type rollers in it. What we measured and talked to others around here was that at .600, the oil hole starts to come out the lifter tube. ya cant really install taller inserts in there due to the dog-bones holding them in. We just figure if we want to go to a taller lobe, we will have to go solid roller. My advice would be to go more ratio on the rockers with longer valves. You can gain some there without changing cam and lifters.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
