Re: How I'm spending my Christmas vacation...
[Re: HemiRick]
#890383
12/29/10 10:17 PM
12/29/10 10:17 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
How did you remove the spot welds? Did you use a good grinder to grind away the spot weld just before the bottom panel and then use a chisel? Keep truckin'..... Thanks..
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: Morty426]
#890386
12/30/10 08:10 PM
12/30/10 08:10 PM
Posts: 1,179 Canada
demon
Canada
Dude - you need to by a spot weld cutter
nope. What he is doing is the best method. Spotweld cutters are great when you want to save the top and bottom panels, but on a rusty crusty trunkfloor the grind thru method is WAY easier and more effective.
[Re: HemiRick]
#890387
12/30/10 08:18 PM
12/30/10 08:18 PM
Posts: 910 North East Texas
TexasPowerRam
super gas
super gas
North East Texas
Where is Haslet? Id love to see your car and the work you have done. Looking good.
John
2008 Ford F250 XLT 4x4 Crew Cab
1990 Ford Crown Victoria LTD, Ex TXDPS
[Re: TexasPowerRam]
#890389
12/30/10 09:14 PM
12/30/10 09:14 PM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
TexasPowerRam... I'm located just outside of Saginaw off of business 287, about a mile from the Saginaw airport. Challenger 1 thanks for your input...funny you would post your ideas about blasting, I have been browsing the web for the last hour or so looking at blasters to do the very thing you suggested. Id like to blast the frame rails and support structure then Rust Bullet them before installing the new metal.
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: RapidusMaximus]
#890390
12/30/10 09:25 PM
12/30/10 09:25 PM
Challenger 1
Cincinnati, Ohio
I knew that was on your your mind from looking at your pictures. Good luck with it.
[Re: Challenger 1]
#890393
12/30/10 09:39 PM
12/30/10 09:39 PM
RapidusMaximus
Weatherford, Texas
Thanks...appreciate the tips...Happy New Year!
#890394
12/30/10 09:47 PM
12/30/10 09:47 PM
TexasPowerRam
super gas
super gas
North East Texas
I'm in Longview. Maybe we can meet up one day.
John
