This is the first time my engine will have been assembled w/ conventional file-fit rings since it was built waaaaay back w/ "gapless" stuff. The PBM-branded rings supplied by the local machine shop that did the re-hone on the cylinders are plasma-moly / reverse back-twist / standard oil tension in the 1/16", 1/16", 3/16" size.
I don't know if I should consider my combination "moderate" or "serious" for gapping purposes. Moderate would use .004 top / .005 2nd per inch of bore diameter vs. .0045 top / .0055 2nd. For a 4.380" bore, that works out to...
Top --> .004 = .018"; .0045 = .020"
2nd --> .005 = .022"; .0055 = .024"
Engine will be spun up to 7K RPM and run w/ 10.8 CR on 93-octane pump gas. Also, the top ring position is .175" below the deck.
Guidance requested.
