Re: Anyone installed Mark Williams billet caps on 8 3/4??
[Re: wafflebatter]
#890076
12/28/10 01:06 PM
12/28/10 01:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
ok I understand, thanks. I think these may be a wise investment, I know there was a thread on this, but what do you think the stock caps can handle? considering my roadster only weighs approx. 1900 lbs. with 600 hp, it is pretty easy on parts, but if it is not worth spending $300 on that, I could put the cash to use somewhere else
I ran a stock cap 8 3/4 for a long time in my car 2400# with me but I finally broke the caps... this was with about 600hp and low 1.20s 60'... I changed to the alum center after that... if I didnt go with the alum center I would have gone with the good caps.... also a back brace helps alot
[Re: poppaj]
#890079
12/28/10 04:04 PM
12/28/10 04:04 PM
MR_P_BODY
I had a set in my 8-3/4 in the coronet. Still blew the ring and pinion. Housing flex causes the problems. If you are over 3000# and have 600+hp consider a Dana 60 or a 9".
The car weighs 1900#
