moroso vacuum pump bearing replacement help #889973
12/27/10 11:58 PM
12/27/10 11:58 PM
glendora, ca.
Deepockets Offline OP
glendora, ca.
just wondering how i might remove the rear bearing from the housing? any do it your self ideas. thanks
Re: moroso vacuum pump bearing replacement help [Re: Deepockets] #889974
12/28/10 01:18 AM
12/28/10 01:18 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
If it were me I would remove everything from the housing and place it on a hot plate then after several minutes turn it over and let it fall out
Re: moroso vacuum pump bearing replacement help [Re: Deepockets] #889975
12/28/10 01:37 AM
12/28/10 01:37 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Have you tried packing the shaft hole with grease and then tapping in a rod or dowel - the pressure on the grease should push out the bearing (similar to removing a bushing in a blind hole).
