Block clearance for 340 stroker? #889623
12/27/10 01:23 PM
12/27/10 01:23 PM
INDIANA
P
Paul Jacobs Offline OP
P
INDIANA
I'm curious if anyone has a good pictre showing how much clearance (if any) is required to clear a stroker kit in a 340 block? A steel rod Eagle setup is what I'm thinking.
Any help is appreciated.
Re: Block clearance for 340 stroker? [Re: Paul Jacobs] #889624
12/27/10 01:42 PM
12/27/10 01:42 PM
Milledgeville, (central) Georg...
Bighead440 Offline
Bighead440  Offline
Eagle SIR rods= no clearancing except the oil pump (IIRC) and Milodon windage tray louvers on my pump gas 416. A stronger setup with no cyl. wall notching was a buddy's 408 with SCAT I-beams. My 416 race setup with K1 H-beams required maybe a pinky-fingertip notch in the opposing wall, and a little on the oil pump (which requires grinding with main studs/nuts anyway). RB
Re: Block clearance for 340 stroker? [Re: Paul Jacobs] #889625
12/27/10 06:00 PM
12/27/10 06:00 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
if you are still thinking and have not bought..
go with the scat 4340 I beam rods...better rod then the SIR ..and only a few dollars more
Tony
70 AARCuda Vitamin C
Re: Block clearance for 340 stroker? [Re: 70AARcuda] #889626
12/27/10 07:08 PM
12/27/10 07:08 PM
Bighead440 Offline
Bighead440  Offline
Re: Block clearance for 340 stroker? [Re: Bighead440] #889627
12/27/10 08:02 PM
12/27/10 08:02 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
X 1000
Re: Block clearance for 340 stroker? [Re: Moparnut426] #889628
12/27/10 08:32 PM
12/27/10 08:32 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
mine cleared with no notch but I notched it a little for safety sake
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Block clearance for 340 stroker? [Re: dusturbd340W5] #889629
12/27/10 08:48 PM
12/27/10 08:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I wont know till tomorrow if it clears... I get the
crank back then and can start mocking things up...
then I'll take the crank back for balancing if it all
works out as planned
Re: Block clearance for 340 stroker? [Re: Paul Jacobs] #889630
12/27/10 09:18 PM
12/27/10 09:18 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
here is my 318 block. 4.250" stroke...
Re: Block clearance for 340 stroker? [Re: StrokerAspen] #889631
12/27/10 10:13 PM
12/27/10 10:13 PM
USA
K
krw71ragtop Offline
krw71ragtop  Offline
K
USA
Can't remember how much was taken out.
Re: Block clearance for 340 stroker? [Re: krw71ragtop] #889632
12/28/10 01:08 AM
12/28/10 01:08 AM
INDIANA
P
P
INDIANA
Thank you guys thats just what I needed to know!
Re: Block clearance for 340 stroker? [Re: 70AARcuda] #889633
12/28/10 10:35 AM
12/28/10 10:35 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Yep, and no clearancing with those either.
