Re: Block clearance for 340 stroker?
[Re: Paul Jacobs]
#889624
12/27/10 01:42 PM
12/27/10 01:42 PM
Posts: 147 Milledgeville, (central) Georg...
Bighead440
I'm curious if anyone has a good pictre showing how much clearance (if any) is required to clear a stroker kit in a 340 block? A steel rod Eagle setup is what I'm thinking. Any help is appreciated.
Eagle SIR rods= no clearancing except the oil pump (IIRC) and Milodon windage tray louvers on my pump gas 416. A stronger setup with no cyl. wall notching was a buddy's 408 with SCAT I-beams. My 416 race setup with K1 H-beams required maybe a pinky-fingertip notch in the opposing wall, and a little on the oil pump (which requires grinding with main studs/nuts anyway). RB
[Re: Paul Jacobs]
#889625
12/27/10 06:00 PM
12/27/10 06:00 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
if you are still thinking and have not bought..
go with the scat 4340 I beam rods...better rod then the SIR ..and only a few dollars more
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Moparnut426]
#889628
12/27/10 08:32 PM
12/27/10 08:32 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
mine cleared with no notch but I notched it a little for safety sake
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#889629
12/27/10 08:48 PM
12/27/10 08:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I wont know till tomorrow if it clears... I get the crank back then and can start mocking things up... then I'll take the crank back for balancing if it all works out as planned ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 70AARcuda]
#889633
12/28/10 10:35 AM
12/28/10 10:35 AM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
Yep, and no clearancing with those either. ![](/ubbthreads/images/graemlins/thumbs.gif)
