108 LSA vs 107 LSA #888474
12/26/10 09:35 AM
12/26/10 09:35 AM
Marysville, O-H-I-O
70Cuda383 Offline OP
Marysville, O-H-I-O
I'm looking at a hyd. roller cam for a 360 cu in motor with Magnum heads, dual plane rpm intake and a carb.
looking at hughes "whiplash cams for magnum motors w/carbs"
they have one thats .544 lift, 222 degrees at .050, on a 107 LSA
how would this run compared to a similar cam that was custom ground, that's .566 lift, 214 degrees duration, and on a 108 LSA?
what would be the characteristics of each one?
trying to decide if the 2nd custom ground cam would work well for me, compared to the "hughes, custom cam for carb'd magnum" cam.
especially at half the price!
**Photobucket sucks**
Re: 108 LSA vs 107 LSA [Re: 70Cuda383] #888475
12/26/10 10:30 AM
12/26/10 10:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
A shorter LSA has more overlap and has that choppy
idle... both of the cams will be a low rpm cam
Re: 108 LSA vs 107 LSA [Re: MR_P_BODY] #888476
12/26/10 10:43 AM
12/26/10 10:43 AM
Marysville, O-H-I-O
Marysville, O-H-I-O
ok, i want that chopy lopey idle. with the 1 degree make that much difference in sound?
if you had to choose between the 2 cams, would you take the one with more duration for $365, or the one with less duration for $130? (keeping in mind a stock truck converter, stall around say, 1800-ish? 4200 lb truck, 3.92 gears with 28" tires0
Pretty sure i've already made up my mind, but i don't want to find myself second guessing my choice, later down the line.
Re: 108 LSA vs 107 LSA [Re: 70Cuda383] #888477
12/26/10 10:44 AM
12/26/10 10:44 AM
Marysville, O-H-I-O
Marysville, O-H-I-O
from my limited understanding, the longer duration cam will be higher in the RPM range, right?
Re: 108 LSA vs 107 LSA [Re: 70Cuda383] #888478
12/26/10 10:52 AM
12/26/10 10:52 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes... I doubt you will see or hear anything with just
1 degree of LSA with all else the same(low LSA has a
higher cranking pressure)
Re: 108 LSA vs 107 LSA [Re: 70Cuda383] #888479
12/26/10 10:55 AM
12/26/10 10:55 AM
IN
ahy Offline
ahy  Offline
IN
The longer duration cam should run higher in the RPM range from my also limited understanding. One thing to check, the stock Magnum valvetrain seems to be good to about .5" lift. Upgrades to springs, seals, studs ect. are probably needed with either of those two cams. The .566 lift version looks like its a very fast rate cam... I'd make sure the stock hydraulic lifters can handle it with required springs.
Re: 108 LSA vs 107 LSA [Re: 70Cuda383] #888480
12/26/10 04:52 PM
12/26/10 04:52 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
The Difference in the 8* duration @ .050 will be far greater then the 1* in LSA
But, 1* tighter LSA is on the bigger cam, witch normaly increases overlap.
But, not in this case as the smaller cam installed stright up @ 108* ICL will not open the intake valve untill 1*ATDC The exhaust will close at 1* BTDC So theres a 2* spread from Overlap "EDIT Stated @ .050 dur."
The bigger cam will have 8* overlap vs none of the smaller cam.
At the same spec ICL the 222 will close the intake valve 38* ABDC vs the 214 @ 35* ABDC
Of the two I dont know whitch one Id pick. Probably the smaller one because you said 3900# and towing. The bigger one would would most likely work just fine too mike
Re: 108 LSA vs 107 LSA [Re: Sport440] #888481
12/26/10 05:04 PM
12/26/10 05:04 PM
scratchnfotraction Offline
IIRC stock mag heads dont take much lift over the .450/.465 lift mark
best measure clearance on the valve guide/retainer/seal to make sure you have enuff clearance for that lift range
Re: 108 LSA vs 107 LSA [Re: scratchnfotraction] #888482
12/26/10 11:55 PM
12/26/10 11:55 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
He's Right, make sure thats addressed before you use either cam. Theres spring seat depth issues too, not being deep enough before coil bind for .450 lift and above.
Im going to guess that by now, 2010/2011, someone has already fixed these issues on your Magnum heads. Better check to be sure if you dont know for sure. mike
Re: 108 LSA vs 107 LSA [Re: Sport440] #888483
12/27/10 12:18 AM
12/27/10 12:18 AM
Marysville, O-H-I-O
Marysville, O-H-I-O
I never said towing. I did say truck, but not towing. it's never going to tow, and is a street cruiser. it's just a heavy street cruiser!
as for the lift issues on stock heads, the cam with the 107LSA is from Hughes, and is advertised as "a hyd. roller cam for a magnum engine with a carb instead of EFI" and says that all you need is their springs and retainers, and it will work on an otherwise stock magnum engine...and is infact, designed specifically FOR the stock factory Magnum engine--Head flow, compression ratio, etc.
The other cam is a custom grind Magnum cam, but the guy was using it in a 408 stroker, and his heads were worked.
Re: 108 LSA vs 107 LSA [Re: 70Cuda383] #888484
12/27/10 01:11 AM
12/27/10 01:11 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Well, with that info Id go with the bigger cam 222 @.050 and 107 LSA and the retainer/spring package from Hughes.
You wont be able to use the other higher lift cam unless the Magnum heads have been previously machined by somebody else or you for more clearence for .550 lift and above to be safe.
From what I hear, the Magnum heads are are definate great upgrade from the older heads for the SB, from the X, J, and the 308 heads. mike
Re: 108 LSA vs 107 LSA [Re: Sport440] #888485
12/27/10 01:29 AM
12/27/10 01:29 AM
Marysville, O-H-I-O
Marysville, O-H-I-O
that's kind of how I've been leaning, since the Hughes cam was designed specifically for a stock stroke magnum engine, vs the other one being designed for ported and worked heads, and a stroker 360 at 408cu in.
the factory 5.9L from the trucks is exactly the same as the 300hp crate motor, they just replaced the EFI manifold for a carb manifold, and replaced the distributor, so that right there is a 50 hp jump from the "production" engines.
the 380hp engines were just different pistons for higher compression, and a different camshaft, again, stock magnum heads.
I figured with just a cam change, I'll fall somewhere in between.
...nowhere near as fast as the truck was with a 383 stroked to 438 with eddy heads and a TKO w/ 4.56 gears in the back, but...it should do alright for a street cruiser.
Re: 108 LSA vs 107 LSA [Re: 70Cuda383] #888486
12/27/10 01:48 AM
12/27/10 01:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I think I would go with the 544... 222@50 because
I believe either one is short on revs but this one will
hang on a bit longer... they both would have lump to
the idle
Re: 108 LSA vs 107 LSA [Re: MR_P_BODY] #888487
12/27/10 12:38 PM
12/27/10 12:38 PM
UK
602heavy Offline
602heavy  Offline
UK
Comparing these two cams @ .050 duration is really a crap shoot & does'nt tell you anything , seat to seat timing #s will give a better idea on how these camshafts will behave (.004-.050") , could be chalk & cheese.
Depending on intensity #s the smaller stick may be longer @ overlap & be a dog down low.
Re: 108 LSA vs 107 LSA [Re: MR_P_BODY] #888488
12/27/10 04:57 PM
12/27/10 04:57 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
I think I would go with the 544... [Email]222@50[/Email] because
the idle
Yep!
In a motor that is dead from the factory at 4800 rpm, the longer cam will help.
Re: 108 LSA vs 107 LSA [Re: 602heavy] #888489
12/28/10 06:16 AM
12/28/10 06:16 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
You really would want more info on the cams lobe profile. With roller cams the 0.050" number only gives a general idea of the cams RPM range, but not the info needed to compare to fairly simular cams. What is the $130 "custom" cam? For that price I would guess it is a reground stock cam?
Re: 108 LSA vs 107 LSA [Re: 451Mopar] #888490
12/28/10 09:24 AM
12/28/10 09:24 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
No recommendation but, thought I would point out:
LSA is given in camshaft degrees meaning, 107º would require
214º of crankshaft rotation from EX c/l to IN c/l.
108º LSA would be 216º @ the crank.
Identical lobes on a 107º and 108º LSA would change overlap value by 2º, not 1º
Re: 108 LSA vs 107 LSA [Re: S/ST 3040] #888491
12/28/10 11:43 AM
12/28/10 11:43 AM
UK
602heavy Offline
602heavy  Offline
UK
As Mike (sport) pointed out , the walking stick ground on a 108 has 2 degree negative overlap @ .050".
Guy over here with a stock 440 just got hold of a FT hyd cam from summit & was asking how it would perform................
Duration @ .004" 286/294
Duration @ .050" 208/216
Lobe sep 110/106 ICL.
Overlap @ .050 = MINUS 8degrees
Overlap @ .004" = + 70 degrees
This stick will be a dog down low but he decided to fit it anyhow , will be a nightmare to tune along with stinking tailpipes , possibly gonna have to lock that distributor out...........he asked me where abouts to install this stick , i told him over the wall.
