Would they fit?
#888023
12/25/10 02:37 PM
12/25/10 02:37 PM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
Hi all
First off Merry Christmas
now my question. Would 295 55 15 M/T drag radials fit on a 15x8 Crager rim, under my 1970 coronet? The leaf springs are in standard location. Thanks Mike
1969 Dodge Dart Swinger
Re: Would they fit?
[Re: MikeyT]
#888025
12/25/10 04:11 PM
12/25/10 04:11 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I am thinking no , but am not the final word on these things. This is the size I have under my '65 dart with mini tubs and springs under the rails. 15 X 10 with 6.5 back space.............there is about 1/2 " to the spring and 1" to the wheel well lip. Unless the B body wheel wells are significantly larger and you figure the right offset , I'd say no chance.
Oooops , forgot to add 2 1/2 " off each side on the housing too.
Re: Would they fit?
[Re: tubtar]
#888026
12/25/10 05:18 PM
12/25/10 05:18 PM
Posts: 9,827 MI, usa
dvw
MI, usa
70 Coronet wheel wells are the largest of any Mopar that I know of. I've seen 295-50x15 on E-Bodys. Personally I think you'll find them looking a little short. I've seen 315 60 15 on 70 Coronet,looks great. My buddys 70 R/T covertile has 275 60 15 on 8" Magnum 500s. They aren't even close to hitting. Doug
Re: Would they fit?
[Re: dvw]
#888028
12/25/10 05:52 PM
12/25/10 05:52 PM
MikeyT
Watertown, WI
A 295 50 15 fits fine with my set up. Gosh a 315-60-15 sounds awfully large! Anyway looks like my set up should be fine!
Thanks all
Mike
Re: Would they fit?
[Re: MikeyT]
#888029
12/25/10 08:47 PM
12/25/10 08:47 PM
Posts: 236 upstate, New York
jvcuda
upstate, New York
On my '73 cuda,I have the et street radials 295-55-15 on a weld 15x8 rim. stock suspension. Here's a short clip at the track. 73cuda
