Would they fit? #888023
12/25/10 02:37 PM
12/25/10 02:37 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Hi all
First off Merry Christmas
now my question. Would 295 55 15 M/T drag radials fit on a 15x8 Crager rim, under my 1970 coronet? The leaf springs are in standard location.
Mike
1969 Dodge Dart Swinger
Re: Would they fit? [Re: MikeyT] #888024
12/25/10 04:09 PM
12/25/10 04:09 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
If the wheels are the correct offset no problem. A 8" wheel is kind of narrow for a 295, I would think it would like a 10"
Doug
Re: Would they fit? [Re: MikeyT] #888025
12/25/10 04:11 PM
12/25/10 04:11 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I am thinking no , but am not the final word on these things.
This is the size I have under my '65 dart with mini tubs and springs under the rails.
15 X 10 with 6.5 back space.............there is about 1/2 " to the spring and 1" to the wheel well lip.
Unless the B body wheel wells are significantly larger and you figure the right offset , I'd say no chance.
Oooops , forgot to add 2 1/2 " off each side on the housing too.
Re: Would they fit? [Re: tubtar] #888026
12/25/10 05:18 PM
12/25/10 05:18 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
70 Coronet wheel wells are the largest of any Mopar that I know of. I've seen 295-50x15 on E-Bodys. Personally I think you'll find them looking a little short. I've seen 315 60 15 on 70 Coronet,looks great. My buddys 70 R/T covertile has 275 60 15 on 8" Magnum 500s. They aren't even close to hitting.
Doug
Re: Would they fit? [Re: MikeyT] #888027
12/25/10 05:40 PM
12/25/10 05:40 PM
Denmark
Dart of Denmark Offline
Denmark
I have 295/50/15 on my old 68 coronet with no problem!
Re: Would they fit? [Re: dvw] #888028
12/25/10 05:52 PM
12/25/10 05:52 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
A 295 50 15 fits fine with my set up. Gosh a 315-60-15 sounds awfully large! Anyway looks like my set up should be fine!
Thanks all
Mike
Re: Would they fit? [Re: MikeyT] #888029
12/25/10 08:47 PM
12/25/10 08:47 PM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
On my '73 cuda,I have the et street radials 295-55-15 on a weld 15x8 rim. stock suspension.
Here's a short clip at the track.
73cuda
Re: Would they fit? [Re: jvcuda] #888030
12/25/10 10:19 PM
12/25/10 10:19 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Nice !
What offset ?
I love those cars with bigg'uns and skinnies on them.
They never gave me the illusion of turning with any kind of vigor............they just look like a drag car.
Re: Would they fit? [Re: tubtar] #888031
12/26/10 04:57 AM
12/26/10 04:57 AM
Louisiana
K
kzinge1 Offline
kzinge1  Offline
K
Louisiana
I have a 69 RR, stock tubs, stock spring location, SS springs. I am running the 295/65 M/T on a 15x8 wheel with 4.5" backspace. Fits perfect, no rubbing.
