Edelbrock Victor head users - How much timing? #886990
12/24/10 01:04 AM
12/24/10 01:04 AM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Anyone who is using (or has tested) Edelbrock Victor heads... what did you end up running for total ignition timing? Also, what CR and octane fuel were you using?
Re: Edelbrock Victor head users - How much timing? [Re: BradH] #886991
12/24/10 02:16 AM
12/24/10 02:16 AM
Delray beach, Florida
P
Performance Only Offline
P
34 degree's 14-1 110 octane
that probably doesn't help you much though.
machine shop owner and engine builder
Re: Edelbrock Victor head users - How much timing? [Re: Performance Only] #886992
12/24/10 02:33 AM
12/24/10 02:33 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Is there a general rule on timing and compression? 34 at 14:1 what would 10:1 pump gas be?
Re: Edelbrock Victor head users - How much timing? [Re: rowin4] #886993
12/24/10 02:36 AM
12/24/10 02:36 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
Victor max wedge here, 13:1, 32 degrees total made best HP on dyno. I haven't touched timing or jetting since it was dynoed. So don't know what "real world", as in, track tested best is.
Re: Edelbrock Victor head users - How much timing? [Re: BradH] #886994
12/24/10 10:50 AM
12/24/10 10:50 AM
NC
440Jim Offline
440Jim  Offline
NC
FWIW, this is what Johnny Burch saw while testing at MIR on 10/24/2010.
542 CID (4.380 x 4.50 stroke), 12.7 CR (0.040" down the hole), 276/280 at 0.050" roller cam, max wedge Victor heads,
in this order as the weather got a little slower as the day went on:
36º, 1.328, 3.814, 5.911@117.10, 7.730, 9.281@144.83
33º, 1.334, 3.827, 5.926@116.97, 7.748, 9.301@144.63
richened carb, then
33º, 1.333, 3.832, 5.935@116.67, 7.761, 9.316@141.38
36º, 1.335, 3.826, 5.926@116.82, 7.750, 9.300@141.23
Re: Edelbrock Victor head users - How much timing? [Re: 440Jim] #886995
12/24/10 11:11 AM
12/24/10 11:11 AM
SW pa
goldenlancer Offline
SW pa
I have a 10 to 1 499 that runs on 93 with no problem runs N/SS B best timing that I found with dish pistons and 150# cranking comp is 40* less is slower on the ET.
N/SS
Re: Edelbrock Victor head users - How much timing? [Re: 440Jim] #886996
12/24/10 11:15 AM
12/24/10 11:15 AM
South Bend, Indiana
mistress Offline
mistress  Offline
South Bend, Indiana
Fully ported Hughes Victor heads. 38 at launch and i pull 3 degrees out in high gear for more MPH. 13:1 on Methanol
Re: Edelbrock Victor head users - How much timing? [Re: mistress] #886997
12/24/10 12:01 PM
12/24/10 12:01 PM
Wisconsin
sjs64polara Offline
sjs64polara  Offline
Wisconsin
505 cross ram engine with 38 deg, 10:1 pump gas 730 hp
Re: Edelbrock Victor head users - How much timing? [Re: sjs64polara] #886998
12/25/10 10:42 PM
12/25/10 10:42 PM
The Great White North
RAMM Offline
RAMM  Offline
471- 11.5 comp 36 total for best power-717 hp.JRob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Edelbrock Victor head users - How much timing? [Re: RAMM] #886999
12/25/10 10:56 PM
12/25/10 10:56 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I don't run Victor head but I am surprised at the amount of timing to gain best power. These numbers reflect those of a stock style iron head. I would think that with a more modern chamber and better plug location they would need less. Has anyone besides Jim tried less during the same day? Just curious
Doug
Re: Edelbrock Victor head users - How much timing? [Re: dvw] #887000
12/26/10 02:03 PM
12/26/10 02:03 PM
BradH Offline OP
BradH  Offline OP
... I am surprised at the amount of timing to gain best power.
Same here, but I had the same observation re: how much timing people seem to run w/ Indy BB heads, too.
Re: Edelbrock Victor head users - How much timing? [Re: BradH] #887001
12/26/10 02:50 PM
12/26/10 02:50 PM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
I haven't tried any adjustments at the track yet, but 32 degrees made more power than 34 on the engine dyno on my setup.
Re: Edelbrock Victor head users - How much timing? [Re: G_bob] #887002
12/26/10 03:59 PM
12/26/10 03:59 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
It also includes rod/stroke ratio and piston head design...
Re: Edelbrock Victor head users - How much timing? [Re: dvw] #887003
12/26/10 06:06 PM
12/26/10 06:06 PM
RAMM Offline
RAMM  Offline
Doug
These heads are not that good. J.Rob
Re: Edelbrock Victor head users - How much timing? [Re: dvw] #887004
12/26/10 06:16 PM
12/26/10 06:16 PM
NC
440Jim Offline
440Jim  Offline
NC
Doug
In my car, I have Indy 440-1 heads, 13.5 CR with flat tops, 68cc, 511 CID, and this is all the ignition timing my motor needs:
