A good way to tighten valve cover nuts? #886978
12/24/10 01:04 AM
12/24/10 01:04 AM
Georgia
W
wh23g3g Offline OP
wh23g3g  Offline OP
W
Georgia
I got these nicer used valve covers than my 400 has. Mine were so warped I could never get to seal but these look ok. I've got them all blasted, cleaned, and painted Chrysler blue and I'm ready to install them. I'm using the hard to get Mopar Performance red silicone gaskets. I've got the standard studs and nuts from Year One except I used them all, no screws. I always mess up by not tightening enough or overtightening. I can never tighten a valve cover properly no matter what kinda car it's been. I used the inch-pounds torque wrench last time but it's old and non-reliable. Is there a foolproof way to tighten these now knowing that I'm using used covers with a good straight flange and silicone gaskets? I'm sure its a simple answer but I want to make sure I cover everything so I don't have to change these again for the 4th time before I've even gotten to drive the car.
Re: A good way to tighten valve cover nuts? [Re: wh23g3g] #886979
12/24/10 04:15 AM
12/24/10 04:15 AM
You dont have a perfectly symmetrical pattern to work with but you crisscross up/down in multiple steps & end up going thru your selected pattern 6 or more times and I have better luck w them ending up being tightened less than what I think they should be (lightly snug) & definitily using your choice of sealer
Re: A good way to tighten valve cover nuts? [Re: wh23g3g] #886980
12/24/10 08:12 AM
12/24/10 08:12 AM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
Use a nut driver to tighten them. That should prevent you from over tightening them .
I also like to use the small little triangle shaped spreader washers to help spread the clamping force out a little.
Re: A good way to tighten valve cover nuts? [Re: ChinooK440] #886981
12/24/10 10:57 AM
12/24/10 10:57 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
I use the red high temp sealer on both sides of the gaskets. Finger tighten all of them or in your case lightly tighten. Let set for 1/2 hour, tighten them 3/4 of a turn. Leave them alone.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: A good way to tighten valve cover nuts? [Re: MOPARMIKE69] #886982
12/25/10 11:09 PM
12/25/10 11:09 PM
Georgia
W
wh23g3g Offline OP
wh23g3g  Offline OP
W
Georgia
Well I'm using the MP red silicone gaskets. I don't think they're rubber at all. I sure hope they seal better than those Ultra Seal from MR. Gasket. Of course I was using those on my old valve covers, but still we flattened the old covers and used the copper-silicone and we got one side to not leak but the other was so bad. I just don't want to have to do this again.
Re: A good way to tighten valve cover nuts? [Re: wh23g3g] #886983
12/26/10 02:34 AM
12/26/10 02:34 AM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Many times the valve cover hangs on the aftermarket runners. Some covers are clearanced on those spots, some are not. Cast covers on SB's are notorious for not sealing as the hang up on these runners. After a little grinding, they sit flush. Use 2 cork gaskets cemented together and you dont have to clearance. Worth checking. 40 inch/lbs or 3.33 ft/lbs is snug at best. Use a nut driver. Can get a way with a little more with a cast cover that doesnt deform.
Re: A good way to tighten valve cover nuts? [Re: pishta] #886984
12/26/10 12:28 PM
12/26/10 12:28 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Cork gaskets are the only ones I use, and the only ones I could ever get to seal. Silicone the gasket on the valve cover side, and snug with a nut driver. Not so much as a seep!
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: A good way to tighten valve cover nuts? [Re: 69L78Nova] #886985
12/26/10 01:08 PM
12/26/10 01:08 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
A lot of people overtighten valve covers and oil pans. The nut driver suggestion is a good one. I prefer "glued" the black ultra seal gaskets to the valve cover with Permatex Ultra-seal after straightening the valvecover metal, especially around the holes. I then coat the side that touches the head with a wet coat of motor oil and tighten evenly with a speed wrench taking care not to over tighten. I check the bolts occasionally and keep them snug.
Re: A good way to tighten valve cover nuts? [Re: jbc426] #886986
12/26/10 01:11 PM
12/26/10 01:11 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
If you are running stock exhaust manifolds, it may be cooking the gasket along the lower rail. I think there was a shield or special gasket made to provide a solution to this?
Re: A good way to tighten valve cover nuts? [Re: jbc426] #886987
12/26/10 05:01 PM
12/26/10 05:01 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It isn't rocket science.
I prefer the silicone coated steel shim gaskets, but I have used all the commonly available types.
I have almost never used RTV, a crutch for poor workmanship, imo.
Flat rails, on the cover and head, fresh gaskets and properly torquing to spec is all that is needed. I might use a spray glue to glue the gasket to the valve cover to ease installation, but I have also used thread to tie the gasket to the cover.
If you get into aftermarket intakes or covers then you prefit and check for issues, fix them and install as above.
Don't be the exception.
Re: A good way to tighten valve cover nuts? [Re: Supercuda] #886988
12/27/10 03:06 AM
12/27/10 03:06 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Those steel shim silicone one's don't work on the SB with stock covers.
Re: A good way to tighten valve cover nuts? [Re: ademon] #886989
12/27/10 12:07 PM
12/27/10 12:07 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Really? I have an 87 318 and a 65 273 that say otherwise.
Again, not rocket science.
