Re: A good way to tighten valve cover nuts?
[Re: wh23g3g]
#886979
12/24/10 04:15 AM
12/24/10 04:15 AM
RapidRobert
You dont have a perfectly symmetrical pattern to work with but you crisscross up/down in multiple steps & end up going thru your selected pattern 6 or more times and I have better luck w them ending up being tightened less than what I think they should be (lightly snug) & definitily using your choice of sealer
[Re: ChinooK440]
#886981
12/24/10 10:57 AM
12/24/10 10:57 AM
Posts: 2,634 Nashville, TN
MOPARMIKE69
Nashville, TN
I use the red high temp sealer on both sides of the gaskets. Finger tighten all of them or in your case lightly tighten. Let set for 1/2 hour, tighten them 3/4 of a turn. Leave them alone.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: pishta]
#886984
12/26/10 12:28 PM
12/26/10 12:28 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Cork gaskets are the only ones I use, and the only ones I could ever get to seal. Silicone the gasket on the valve cover side, and snug with a nut driver. Not so much as a seep!
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: 69L78Nova]
#886985
12/26/10 01:08 PM
12/26/10 01:08 PM
Posts: 3,278 West Coast, USA
jbc426
West Coast, USA
A lot of people overtighten valve covers and oil pans. The nut driver suggestion is a good one. I prefer "glued" the black ultra seal gaskets to the valve cover with Permatex Ultra-seal after straightening the valvecover metal, especially around the holes. I then coat the side that touches the head with a wet coat of motor oil and tighten evenly with a speed wrench taking care not to over tighten. I check the bolts occasionally and keep them snug.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#886986
12/26/10 01:11 PM
12/26/10 01:11 PM
jbc426
West Coast, USA
If you are running stock exhaust manifolds, it may be cooking the gasket along the lower rail. I think there was a shield or special gasket made to provide a solution to this?
[Re: jbc426]
#886987
12/26/10 05:01 PM
12/26/10 05:01 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
It isn't rocket science.
I prefer the silicone coated steel shim gaskets, but I have used all the commonly available types.
I have almost never used RTV, a crutch for poor workmanship, imo.
Flat rails, on the cover and head, fresh gaskets and properly torquing to spec is all that is needed. I might use a spray glue to glue the gasket to the valve cover to ease installation, but I have also used thread to tie the gasket to the cover.
If you get into aftermarket intakes or covers then you prefit and check for issues, fix them and install as above.
[Re: Supercuda]
#886988
12/27/10 03:06 AM
12/27/10 03:06 AM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
Those steel shim silicone one's don't work on the SB with stock covers.
