Z-bar Bracket Mounting.. #88677
07/14/08 08:33 PM
07/14/08 08:33 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I'm on the fence about what clutch linkage to go with.
I want mechanical for simplicities sake, but I'm having trouble with the idea of putting the frame bracket in the wrong plate.
Is there a template or a measurement that can be taken from a similar car that will ensure the proper placement of the bracket ?
I've driven my friends car with the bracket in the wrong place and it is horrible. At least with the hydraulic set up, the placement isn't an issue.
Pictures would be very appreciated...
Thanks !
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Z-bar Bracket Mounting.. [Re: AlexP] #88678
07/14/08 09:28 PM
07/14/08 09:28 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
What kind of car????
Careful, your character's showing!
Re: Z-bar Bracket Mounting.. [Re: mopar346] #88679
07/14/08 09:53 PM
07/14/08 09:53 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
68 Roadrunner
Re: Z-bar Bracket Mounting.. [Re: AlexP] #88680
07/15/08 07:32 PM
07/15/08 07:32 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Re: Z-bar Bracket Mounting.. [Re: AlexP] #88681
07/15/08 08:02 PM
07/15/08 08:02 PM
mopar346 Offline
mopar346  Offline
My immediate thought is that it is a bolt on bracket at the frame. It has been many years since I built my Satellite and have not gotten to that point on my RR. I can check this weekend for you if no one else replies.
Re: Z-bar Bracket Mounting.. [Re: mopar346] #88682
07/15/08 08:13 PM
07/15/08 08:13 PM
mopar346 Offline
mopar346  Offline
Brewer shows it as a weld in like an E-body, can get measurement s this weekend have the motor and suspension out of the RR.
Re: Z-bar Bracket Mounting.. [Re: AlexP] #88683
07/15/08 09:05 PM
07/15/08 09:05 PM
Central, NY
DanMcG Offline
DanMcG  Offline
Central, NY
I could get ya a pic or two in the morning if it will help. Do you have the bracket already?
Dan
Re: Z-bar Bracket Mounting.. [Re: DanMcG] #88684
07/16/08 12:23 AM
07/16/08 12:23 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I don't have the bracket yet, but the ones I have seen for my car appear to be weld in.
Any pictures that you guys have would be greatly appreciated. I really don't want to mess this one up....
Re: Z-bar Bracket Mounting.. [Re: AlexP] #88685
07/16/08 05:44 AM
07/16/08 05:44 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Don't know about B-bodies, but on my E-body 71 barracuda, the drivers frame rail has a rectangular notch in it about 3/16 wide and one inch long. The original z-bar bracket that I have has a similar male section that fits into this female slot - it only fits in one location and only one way. The z-bar bracket was tacked in multiple locations to its original frame rail.
Re: Z-bar Bracket Mounting.. [Re: larry4406] #88686
07/16/08 06:16 AM
07/16/08 06:16 AM
Central, NY
DanMcG Offline
DanMcG  Offline
Central, NY
I was wondering, does your inner fender have the oblong hole in it to get at the ball stud mounting nut?
I will have to scrape off an inch of grease to get a good pic of the mount itself, but i don't see a problem getting it located accurately.
Dan
Re: Z-bar Bracket Mounting.. [Re: larry4406] #88687
07/16/08 08:28 AM
07/16/08 08:28 AM
Central, NY
DanMcG Offline
DanMcG  Offline
Central, NY
I was just looking at brewer's web site. I think the pic shows the bump in the bracket that Larry mentions. If thats the case placement would be a no brainer...Good Luck, Dan
http://www.brewersperformance.com/proddetail.asp?prod=FB470
Re: Z-bar Bracket Mounting.. [Re: DanMcG] #88688
07/16/08 08:34 AM
07/16/08 08:34 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The 68-69 B body doesn't have the notch in the frame for that tab, it will need to be ground off to get it to sit flat .
Also yes it has that access hole in the inner fender .
Re: Z-bar Bracket Mounting.. [Re: JohnRR] #88689
07/16/08 12:46 PM
07/16/08 12:46 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Brewers is going to send me a few pictures of how it is all located on the frame, that they say should help me get it in right.
They reccomend installing the bracket once the bellhousing is in the car because of my Lakewood bell.
Re: Z-bar Bracket Mounting.. [Re: AlexP] #88690
07/16/08 12:53 PM
07/16/08 12:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
They recommend installing the bracket once the bellhousing is in the car because of my Lakewood bell.
Thats a very good suggestion from them , i have seen issues with that brackets alignment with the lakewood .
Re: Z-bar Bracket Mounting.. [Re: JohnRR] #88691
07/16/08 01:21 PM
07/16/08 01:21 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Yep, that's about the only thing that worries me about the swap. I'm not going to have any used parts in the linkage itself so I shouldn't have a horrible time. Once I get the last of the odds and ends, this shouldn't be much more than a weekend swap.
Re: Z-bar Bracket Mounting.. [Re: AlexP] #88692
07/16/08 07:53 PM
07/16/08 07:53 PM
In a town not near you.
clownzilla Offline
clownzilla  Offline
If you have problems with the Z-bar being too long because of bellhousing size you may have to cut a piece out of the center of the Z-bar shaft, mock it up and weld it to the right size.
This is what I ran into with my barracuda Z-bar since I went with the bigger clutch bellhousing.
The early bird gets the worm, and the second mouse always gets the cheese.
