Re: NSS cross ram carbs
[Re: sjs64polara]
#886711
12/23/10 08:39 PM
12/23/10 08:39 PM
Posts: 535 Ohio
racerAL
Ohio
well i can't afford them, but i think that these are some of the best out there. http://www.diamondbackengines.com/
-1967 Plymouth Satellite #3555 446 cid on E-85 best 1/4 et 10.577 @ 127.58 best 1/8 et 6.722 @ 100.68 best 60ft. 1.419
[Re: junkyardmaxie]
#886713
12/23/10 09:12 PM
12/23/10 09:12 PM
Posts: 1,186 OHIO
THE GLASS MAN
OHIO
old super stock -max wedge racer i think he is in flordia DAN DVORAK PHONE NUMBER ?
Dan Dvorak of Dvorak Machine in Waldo Florida. How many years did Dan hold the a/stock automatic record with a cross ram max wedge? 10 ?
[Re: sjs64polara]
#886717
12/24/10 12:06 AM
12/24/10 12:06 AM
I've been told my car will slow down .2 - .3 going to eddy's. Do you think that is true I'm currently in the high 10's
NOT TRUE AT ALL!
[Re: ro23car]
#886719
12/24/10 02:47 AM
12/24/10 02:47 AM
Posts: 417 reynoldsburg,ohio
poppaj
reynoldsburg,ohio
Holleys are a definite no for NSS unless you run 9.25 or quicker. Damon at Diamondback builds excellent carbs.
AA/NSS 65'Coronet "Whompin Wedge" Pop & Son Performance 557" B-1 power John Holt Chassis
[Re: poppaj]
#886720
12/24/10 09:43 AM
12/24/10 09:43 AM
Posts: 6,350 Aurora, Oh.
max_maniac
Aurora, Oh.
Really???? I did not know that. So why would the Holleys be allowed if you run a faster time? Does not make sense to me
Russ
[Re: max_maniac]
#886721
12/24/10 10:12 AM
12/24/10 10:12 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Because it then falls into the afx rule. I have never seen holleys make any more power when on a factory cross ram. You are limited to the power potential of the intake. I have modified edelbrocks for the crossram or original carbs in stock. Jake
JAKES AUTOMOTIVE
[Re: JAKE68]
#886722
12/24/10 10:46 AM
12/24/10 10:46 AM
Posts: 1,162 s e mich
ro23car
s e mich
good man right here merry christmas jake.
[Re: JAKE68]
#886725
12/24/10 11:12 AM
12/24/10 11:12 AM
Posts: 449 Wisconsin
sjs64polara
Wisconsin
Could you get more HP using holleys with the Indy inline cross ram I know the manifold adds more but how about the carbs
[Re: sjs64polara]
#886727
12/24/10 02:10 PM
12/24/10 02:10 PM
Posts: 37 Wisconsin
StillRock69
Wisconsin
The Nostalgia Super Stock National Association and National Muscle Car Association uses these rules -
1.19 CARBURETOR CARBURETOR (NSS CLASSES): All entries in the eliminator must be carbureted as outlined below. Carburetors must be of type and design as originally produced for a specific vehicle. Positioning of carburetors from factory mounting not a tech item (carburetors may be positioned facing forwards, backwards, or side mounted). Choke plate, choke shaft, choke linkage, and choke mechanism may be removed; choke horn removal permitted. The following carburetor combinations are allowed, regardless of year/make/model of entry:
•Buick 400-455; Single Carter, AFB, Edelbrock Performer or Q-Jet, inline 2x4 with Carters, AFBs or Edelbrock Performers. Chevy 396,454 (F/X only): single 4 bbl with Carter AFB, Edelbrock Performer or Rochester. •Chevy 348-409; Inline 2x4, inline 3x2 with Rochesters or single 4bbl with Carters, AFBs, Edelbrock Performers or Rochesters. •Chevy 396-454; Single 4bbl with Rochester, Carter,AFB, Edelbrock Performers or Holley, Inline 2x4 with Carters, AFBs, Edelbrock Performers or Holleys, Inline 3x2 Holleys. •Chrysler Hemi; Inline 2x4 or single 4bbl intake with Carters, AFBs, Edelbrock Performers, Holleys; or cross-ram 2x4 intake with Holleys. •Chrysler Wedge; Inline or cross-ram 2x4 or single 4bbl intake with Carters, AFBs, or Edelbrock Performers. •Ford; Inline 2x4 intakes, inline 3x2, or single 4bbl with Holleys. •Pontiac; Inline 2x4 intakes or single 4bbl with Carters, AFBs, or Edelbrock Performers; or inline 3x2 with Rochesters. •AMX 390— Single Carter AFB or Edelbrock Performer, Cross ram 2x4 bbl intakes with Holleys. •Olds 400-455; 1x4 Q-Jet, inline with 3x2 Rochesters. CARBURETOR (F/X CLASSES): Vehicles in these classes permitted the use of carburetors listed for NSS, or Holley up to 850 cfm in size (no Dominators). Aerosol carburetor(s) prohibited.
Multiple Carburetion Preferred
Racers with current legal National Muscle Car Association and Monster Mopar Dave Duell Classic single 4-bbl carburetor/intake manifold/vehicle combinations are encouraged to change to multiple carburetion. Racers with combinations currently under construction are also encouraged to use multiple carburetion.
1.20 FUEL INJECTION FUEL INJECTION: Era-correct mechanical fuel injection permitted in F/X classes only.
1.21 INTAKE MANIFOLD INTAKE MANIFOLD: In general, common commercial market cast units are preferred and required if available. Sheet metal units allowed only in AAA, AA and A/FX classes and only after inspection by the rules committee. Top of manifold lid may be modified and fabricated as necessary to accommodate carburetor placement. -------------------------------- In general, there is no technical reason why a race car equipped with Holley carbs should necessarily be faster than one with Carter/Edelbrocks given identical engine/chassis/weight and so on.
Currently, there are some legal NSS cars with Indy intakes and Edelbrock carbs running in the 8's. In addition, there are many Indy/Carter or Edelbrock combinations which run in the 9's.
[Re: sjs64polara]
#886729
12/24/10 05:03 PM
12/24/10 05:03 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I find it interesting that even though the very first Cross Ram equipped Hemis came from the factory with dual Carter AFBs, NSS does not allow them on a Cross Ram Hemi?
[Re: ScottSmith_Harms]
#886730
12/24/10 05:35 PM
12/24/10 05:35 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
They need to "lighten" up a bit on the NSS rules for carbs,,, ( im sure i'll get flamed for that ) I did buy some edelbrocks,,,that have been "tweaked" ,,, that will go on a new 540-572 someday,,,but until then,,,it's PRO class city with my "fast" holley...that the guy in the stands cant even see under my hood .. lol
[Re: 69CHARGERMD]
#886731
12/24/10 06:47 PM
12/24/10 06:47 PM
Posts: 3,837 Central Missouri Fort Leonard...
mopar65
hey doug how have you been? hope you and the familey have a merry christmas and a happy new year.
but on the carbs what all has been done to them? i am going to have to get something done to the carter carbs that i have on my tunnelram.right now they dont want to idle worth a dam untill the engine temp gets up to 120 degrees.thanks Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: sjs64polara]
#886733
12/25/10 07:53 PM
12/25/10 07:53 PM
Posts: 37 Wisconsin
StillRock69
Wisconsin
What class could I run if I wanted to keep my holleys
They work good on the street and I find them easy to work on plus they are paid for
Minimum would be C/FX 9.75 or quicker; B/FX 9.50; A/FX 9.25; AA/FX 9.00 or AAA/FX 8.75
[Re: JAKE68]
#886734
12/25/10 07:57 PM
12/25/10 07:57 PM
ro23car
s e mich
9.0-9.25-9.5 are the classes you can run with holleys in most organizations.
jake wasnt corda runnin 10.0 with is dart?
[Re: StillRock69]
#886735
12/25/10 07:59 PM
12/25/10 07:59 PM
ro23car
s e mich
i thought the index was on the time the car ran. not the type of car or carb on the car
[Re: ro23car]
#886737
12/25/10 08:28 PM
12/25/10 08:28 PM
Posts: 37 Wisconsin
StillRock69
Wisconsin
"Carburetor (F/X Classes): Vehicles in these classes permitted the use of carburetors listed for NSS, or Holley up to 850 cfm in size (no Dominators). Aerosol carburetors prohibited."
In Nostalgia Super Stock Eliminator, regardless of make, if a racer chooses to run C/FX 9.75 or quicker, a Holley(s) 850 cfm or smaller is legal.
[Re: StillRock69]
#886738
12/25/10 08:45 PM
12/25/10 08:45 PM
ro23car
s e mich
so when al ran his 68 dart at 10.0 index he was legal with his xram carbs.
[Re: muntz1]
#886740
12/25/10 09:18 PM
12/25/10 09:18 PM
poppaj
reynoldsburg,ohio
You are right, 9.75 for holleys, 9.25 for a sheet metal intake. my bad.
[Re: nss guy]
#886741
12/25/10 09:19 PM
12/25/10 09:19 PM
ro23car
s e mich
I belive Corda's ( abert lee) dart is running a wedge motor with the indy intake and afb's. not a hemi
what kind of 68 dart came with more than 1 carb other than a hemi?
[Re: ro23car]
#886742
12/25/10 09:34 PM
12/25/10 09:34 PM
Posts: 396 California, USA
Phil Saran
California, USA
What is the NSS's take on the tall scoop on the hood? Allowed or no?
Phil Saran
Parker, Colorado
[Re: ro23car]
#886743
12/25/10 09:39 PM
12/25/10 09:39 PM
Posts: 37 Wisconsin
StillRock69
Wisconsin
------------------------------------ ELIGIBLE YEAR MODELS AND BODY STYLES
The following is a list of cars/engines which are allowed to compete in Nostalgia Super Stock Eliminator:
• AMC AMX: 1968 – 1969; 390 • Chevrolet Full Bodied: 1959-64;348 & 409s, Z11 427 • Chevrolet Full Bodied: 1965-67;396-454 • Chevrolet Chevelle: 1964 – 1967; 396-454 • Pontiac Full Bodied: 1959-67;389-455 • Tempest/GTO: 1961-67;389-455 • Ford Full Bodied: 1959-67;390-427 • Ford Thunderbolt: 1964;427 • Fairlane/Comet/Cyclone/Falcon: 1963-67;427 • Dodge/Plymouth Full Bodied: 1960-67;383-440 wedge • Dodge/Plymouth Full Bodied: 1964-67;Hemi • Buick Full Bodied: 1960-67;401-455 • Skylark GS: 1964-67;400-401-455 • Oldsmobile Full Bodied: 1960-67;394-400-455 • Cutlass/442: 1964-67;400-455 • Dart/Barracuda: 1967-69;383-440 • Dart/Barracuda: 1968;426 Hemi ---------------------------------- All Classes
All NSS Eliminator participants must declare and post the NSS or FX class of choice at the time of technical inspection or prior to the first scheduled qualifying run of the eliminator. No change of class is permitted after the first scheduled qualifying round.
[Re: Phil Saran]
#886744
12/25/10 09:46 PM
12/25/10 09:46 PM
Posts: 37 Wisconsin
StillRock69
Wisconsin
----------------------------- 7.7 HOOD/SCOOP HOOD/SCOOP (NSS CLASSES): Hoodscoops limited to OEM equipment or period style. Hood/scoop may be no higher than 5 inches. Pro Stock style scoops prohibited. The entire induction system must be completely covered by hood or scoop, which must be part of the vehicle hood.
HOOD/SCOOP (F/X CLASSES): Not required.
[Re: StillRock69]
#886745
12/25/10 10:03 PM
12/25/10 10:03 PM
ro23car
s e mich
i knew that if al had a hemi. it would have 2 carbs. i was just asking because as far as i know no 68 darts had multiple carbs other than a hemi.
[Re: ro23car]
#886747
12/25/10 10:34 PM
12/25/10 10:34 PM
Posts: 37 Wisconsin
StillRock69
Wisconsin
Just to publically confirm, at the 2010 Dave Duell Nostalgia Super Stock Nationals (Monster Mopar) event, according to the tech sheet in my possesion with mine and his signatures (9/10/10), Corda ran a legal combination, a 1969 Dodge Dart in NSS/A 10.00 with an RB wedge, an Indy cross ram and two Edelbrock Performer carbs.
[Re: StillRock69]
#886748
12/25/10 10:51 PM
12/25/10 10:51 PM
ro23car
s e mich
ok my boo-boo thought he had a 68 but i really dont care about the carb issue.
[Re: StillRock69]
#886750
12/26/10 12:05 PM
12/26/10 12:05 PM
sjs64polara
Wisconsin
Ok 9’s is not going to happen I’m more in the high to mid 10 zone, so what class can I run if I keep my holleys. I like my combo for how the car is used; now I’d like to attend more racing events. I’m ok not fitting in with the NSS class but would like to participate with similar type cars. Not Honda Accords, new diesel trucks, tuners, Suv’s, etc.
[Re: sjs64polara]
#886751
12/26/10 12:24 PM
12/26/10 12:24 PM
JAKE68
Shelby mi.
you cannot use the holleys for any nss 10 sec classes.
JAKES AUTOMOTIVE
[Re: JAKE68]
#886752
12/26/10 12:30 PM
12/26/10 12:30 PM
ro23car
s e mich
hey jake was sammy clause good to ya?
[Re: dvw]
#886753
12/26/10 01:02 PM
12/26/10 01:02 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
the national set of rules were laid out to try and preserve the original intent of the class.
Ok, but along that line of thinking regardless of what carbs ARE allowed (that never came stock on some of them) wouldn't it at least make sense to allow carbs that DID come stock on them? I have no dog in this hunt, just curious.
[Re: JAKE68]
#886754
12/26/10 01:10 PM
12/26/10 01:10 PM
sjs64polara
Wisconsin
Understood please re-read post, I wanted to know what class I could run or am I stuck racing Hondas in brackets
[Re: sjs64polara]
#886755
12/26/10 01:13 PM
12/26/10 01:13 PM
ro23car
s e mich
it sounds like your racing the ricers. i know some guys that have eddys and ran great jake is one of them terry thurman another and mark bredernitz is another.
[Re: sjs64polara]
#886757
12/26/10 02:10 PM
12/26/10 02:10 PM
Posts: 1,400 Wi.
old_racer
Wi.
In the NMCA you could run the nostalgia muscle car class. 10:50 or 11:00 flat class with your et. lots of nice cars in that class. Russ
[Re: old_racer]
#886759
12/26/10 02:33 PM
12/26/10 02:33 PM
poppaj
reynoldsburg,ohio
Paul Haulbra went 8.74@152 and Jake went 8.99@150 with Eddy's Both 63' Savoy's...Eddys work. Our car has been 1.29flat 60'
[Re: old_racer]
#886760
12/26/10 02:58 PM
12/26/10 02:58 PM
sjs64polara
Wisconsin
Thank you , that’s exactly what I’m looking for. I’d like to run one more year before switching carbs. I like to do one change at a time on the car, run it several times, and record the results. Switching carbs as well as all the other weight loss and suspension updates I plan on doing this season may get me in a tail spin. I’m rather new to racing so sometimes I have to learn the hard way.
I now understand going to eddys wont kill my et. My intension was not to wrinkle any feathers. I wanted to know more about eddy carbs and classes. I built a street car with a cross ram for fun and did a lot of t&ts last summer at some tracks and now I’m starting to get it in my blood.
