How much Faster 4.00 stroker #885921
12/23/10 12:10 AM
12/23/10 12:10 AM
NC
barracuda man Offline OP
NC
Thinking about a stroker sb.I'm at 344cu now best et 6.85et 98 mph.Leaving everything the same intake/headers ect.What will 416cu do for et and mph. [/image]
Re: How much Faster 4.00 stroker [Re: barracuda man] #885922
12/23/10 12:15 AM
12/23/10 12:15 AM
Delray beach, Florida
P
Performance Only Offline
P
if you leave EVERYTHING the same, you'll have a high torque low reving combo. SB strokers have different component requirements than a stock stroke combo.
machine shop owner and engine builder
Re: How much Faster 4.00 stroker [Re: Performance Only] #885923
12/23/10 12:37 AM
12/23/10 12:37 AM
NC
NC
Lets say i keep the rpm air gap and Eddy 340 heads.Will it run faster at 416cu.
Re: How much Faster 4.00 stroker [Re: barracuda man] #885924
12/23/10 12:42 AM
12/23/10 12:42 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Give use the low down on the whole car, engine,trans,
gear and tire size as well as the total weight and
what conv ... rpm at the traps
Re: How much Faster 4.00 stroker [Re: barracuda man] #885925
12/23/10 01:47 AM
12/23/10 01:47 AM
P
P
the increased torque should make it faster, how much is hard to say since i don't have any other engine info to go on.
Re: How much Faster 4.00 stroker [Re: Performance Only] #885926
12/23/10 04:22 AM
12/23/10 04:22 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
It might run faster if your carb is not to small, might stay about the same, how bout a bit more detailed info?
Post deleted by moparts [Re: ademon] #885927
12/23/10 03:04 PM
12/23/10 03:04 PM
Re: How much Faster 4.00 stroker #885928
12/23/10 04:49 PM
12/23/10 04:49 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Long, long time ago i had a 340( original motor) in my 70 Duster. I had added bolt ons, and then put eddie heads on it. I had Hensley build me a 416 using my heads and a core block they had in inventory. I asked Ken Hensley how much better a 416 would run than a 340 if they both had the same heads, headers, intake,cam and carb.He told me 3 or 4 tenths.
I went with about 1 more point in compression, a bigger cam, and had the heads stage 2 ported at that time, so some definate changes over how the 340 was set up. I threw the 416 in the car and it picked up a touch over a full second over the 340.
But, bit more squeeze, more lift and duration on the cam, and the stage 2 port job. Convertor, gears, carb and intake, headers remainded the same.
Your results may vary. IMO, with a 2 sizes to small head like an eddie on a 416, the gains wont be as significan on a stroker over a stock stroke motor( but as i said above, still very noticable) with good heads more suited to a stroker( Indy, W5, etc,)
the gains going to a stroker and swapping those " good" heads over might be a good bit better, perhaps.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: How much Faster 4.00 stroker [Re: B3422W5] #885929
12/23/10 09:38 PM
12/23/10 09:38 PM
NC
NC
This is what i won't to here.
Re: How much Faster 4.00 stroker [Re: barracuda man] #885930
12/24/10 10:26 AM
12/24/10 10:26 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
FWIW I put together a 422 inch pump gas shortblock for a friend Kindafast here on the site, he used every part that was on the high comp 340 with eddy heads. Same Everything.
Went from 11.70s to 10.90s first run off the trailer.
Dropped approx 1.5 comp and picked up approx 80 inches and picked up 7-8tenths with maybe 2-3tenths left in the setup.
