How are you guys adding weight? #885510
12/22/10 02:24 PM
12/22/10 02:24 PM
412 SB Duster Offline OP
Looking for different ideas on how to mount weight in the back, that can be removed when needed.
thanks
AL
Re: How are you guys adding weight? [Re: 412 SB Duster] #885511
12/22/10 02:35 PM
12/22/10 02:35 PM
Wisconsin
sjs64polara Offline
sjs64polara  Offline
Wisconsin
thanks
AL
Good Topic
Re: How are you guys adding weight? [Re: 412 SB Duster] #885512
12/22/10 02:36 PM
12/22/10 02:36 PM
Locomotion Offline
Locomotion  Offline
I have a pair of metal battery boxes in the trunk bolted through the frame rails with 1/2" bolts. Weight in the form of shot bags or iron bars are added or removed as needed. I also have a 25 lb barbell weight bolted where the spare tire goes. Fuel cell is on a "bridge" frame above the wheelwell. I downsized from a 10 gal. to a 5 gal. because I figured using extra fuel as ballast wasn't a good idea.
Re: How are you guys adding weight? [Re: Locomotion] #885513
12/22/10 03:04 PM
12/22/10 03:04 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
I've got a 100 lb. steel bar that I can mount in the trunk with two 1/2" bolts that go though the bar and the rear frame rails. Slows my et by .11
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: How are you guys adding weight? [Re: nhramark] #885514
12/22/10 06:16 PM
12/22/10 06:16 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I needed my weight in the front and founded 3 lead bars(looks like weight on a x-cise machine)from a foundry.I tig welded 2 small 3/8" plates to bolt them down too and I use grade 8 bolts to bolt them down. They are 25 lbs each. You could go to Wal-Mart or just about any Sporting goods store and buy bar bell weights,they range from about 2-50 lbs each.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: How are you guys adding weight? [Re: MRMOPAR622] #885515
12/22/10 07:41 PM
12/22/10 07:41 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I used to add weight to my 63 Dodge to slow it down for N/SS. It had plates with 1/2" nuts welded just below the floor under the package shelf area. There was a plate with a 1/2" hole located directly between the nuts. The nuts were spaced far enough apart to fit the diameter of 25lb dumb bell wieghts. A piece of 1 1/2" angle iron was layed across the weight with a 1/2" pin through the middle hole of the weight. The angle iron held the weights down with the 1/2" bolt on each side screwed into the floor nuts. The 1/2" bolts and the pin were long enough that I could stack 8 wieghts side by side. You could stack 16 25lb wieghts right above the axle and change them very quickly. loosen the bolts lift the pin up, slide the required weight in or out, reinstall the pin and tighten the bolts.
Doug
Re: How are you guys adding weight? [Re: dvw] #885516
12/22/10 07:47 PM
12/22/10 07:47 PM
Outside
thedriver Offline
thedriver  Offline
Outside
i generally stick my 6 yr old in the trunk when i need the ballast. hes about 65lbs. i tell him to try to stay in the middle, but sometimes when i make the e-brake 180's he slides around back there and the whole damn car wobbles............
1973 challenger
Dana. 4 speed. Low deck.
Re: How are you guys adding weight? [Re: 412 SB Duster] #885517
12/22/10 08:09 PM
12/22/10 08:09 PM
organ
maximum entropy Offline
organ
50# of lead in the rear bumper (50" behind the rear axle!), and a 40# plate bolted to the floor in the spare tire well. big block "a" body, so it needs it.
Re: How are you guys adding weight? [Re: 412 SB Duster] #885518
12/22/10 08:13 PM
12/22/10 08:13 PM
Burlington, Ontario Canada
Dave_S Offline
Dave_S  Offline
Extra helpings of turkey and gravy!! Oh and when they ask what kind of pie for dessert, just say "Yes Please"!!
Merry Christmas
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: How are you guys adding weight? [Re: Dave_S] #885519
12/22/10 11:15 PM
12/22/10 11:15 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Let's just say that you'd better be ready when you remove the tail lamps from my Duster. To help out, there are some little touches up front: basically nothing in the dash behind the panel & bezel (even the ashtray is just the outer cover), aluminum fasteners on the front sheet metal, and the front driveshaft hoop was made from aluminum (it now hangs in the shop). I added some lead bars in the spare tire well between & behind the 2 batteries.
One of the sister Hamburger cars has filler caps & drains in the rear frame rails, and a plate sandwiched into the rear floor.
Re: How are you guys adding weight? [Re: topside] #885520
12/23/10 02:32 PM
12/23/10 02:32 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
A friend of mine used to own one fo Hamburgers old Dusters. It ran NHRA stock. Lets say it looked stock but was a lot heavier in the rear than the front compared to a factory Duster. It ran as the Steel City Missle, Later went to Loge as the California Missle.
Doug
Re: How are you guys adding weight? [Re: dvw] #885521
12/23/10 03:31 PM
12/23/10 03:31 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
When the wife say's, cherrie or apple pie I say yes.
Re: How are you guys adding weight? [Re: dvw] #885522
12/23/10 03:39 PM
12/23/10 03:39 PM
Gilbert, AZ
Aspen7695 Offline
Aspen7695  Offline
Gilbert, AZ
I have 2 2"X4"X40" pieces of steel tubing mounted in the trunk. They are bolted thru the frame rails. Since they are hollow I have a cap on them and I fill them with lead shot. Each bar weighs 95 pounds when full of shot.
Raul
Re: How are you guys adding weight? [Re: 412 SB Duster] #885523
12/23/10 04:58 PM
12/23/10 04:58 PM
ill
dennismopar73 Offline
ill
i'm always trying to figure out how to take weight out go faster
Re: How are you guys adding weight? [Re: topside] #885524
12/23/10 05:03 PM
12/23/10 05:03 PM
ill
ill
i see how you figured it out put halve the car on the trailer!!!
Re: How are you guys adding weight? [Re: dennismopar73] #885525
12/23/10 05:10 PM
12/23/10 05:10 PM
Locomotion Offline
Locomotion  Offline
When I had my 360 W-2 bracket Challenger I added about 140 lbs and picked up .......................consistency
Re: How are you guys adding weight? [Re: Locomotion] #885526
12/23/10 06:12 PM
12/23/10 06:12 PM
I didn't think you ever weighed 140 lbs Myron
Re: How are you guys adding weight? [Re: ] #885527
12/23/10 06:36 PM
12/23/10 06:36 PM
Q
Quicktree Offline
Quicktree  Offline
Q
he still doesn't on that bean sprout diet he's on
Re: How are you guys adding weight? [Re: 412 SB Duster] #885528
12/23/10 06:56 PM
12/23/10 06:56 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
fat chick from the bar,usually good for 250 lbs.
Re: How are you guys adding weight? [Re: fishy340] #885529
12/23/10 08:05 PM
12/23/10 08:05 PM
NW of Indy
Thackdaddy Offline
Thackdaddy  Offline
NW of Indy
Farmall wheel weights work good in the spare tire well of a Duster, 150lbs each.
'71 Duster
