Cuda trunk wiring pictures #885242
12/21/10 11:13 PM
12/21/10 11:13 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Does anyone have pictures of the trunk wiring path for an e body? Tail light to over the wheel well housing.
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: Cuda trunk wiring pictures [Re: 19cuda73] #885243
12/23/10 12:46 AM
12/23/10 12:46 AM
Arizona
Chucklehead Offline
Chucklehead  Offline
Arizona
Only picture I could find from the 72 that shows.maybe it give you an idea of how it went over the wheel house.
Still Broke
Re: Cuda trunk wiring pictures [Re: Chucklehead] #885244
12/23/10 12:47 AM
12/23/10 12:47 AM
Arizona
Chucklehead Offline
Chucklehead  Offline
Arizona
one more
Still Broke
Re: Cuda trunk wiring pictures [Re: Chucklehead] #885245
12/23/10 12:54 AM
12/23/10 12:54 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
one more
Well your 72 isn't routed properly.... See the plastic loop taped to the harness? it should be attached to a clip on the left side up high on the trunk jamb..., the wires route over the wheelhouse the along the top edge of the trunk.. It drops down along the outside of the left tail light & passes across the bottom of the tail panel... Fact is if you look at the first picture you'll see the tab under the trunk jamb...
Re: Cuda trunk wiring pictures [Re: 1_WILD_RT] #885246
12/23/10 02:39 AM
12/23/10 02:39 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
70-71 Cuda
Re: Cuda trunk wiring pictures [Re: Snoopy] #885247
12/23/10 02:52 AM
12/23/10 02:52 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
70-71 Cuda
Don't get better than that...
Re: Cuda trunk wiring pictures [Re: 1_WILD_RT] #885248
12/23/10 10:12 AM
12/23/10 10:12 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I can get better if needed
Re: Cuda trunk wiring pictures [Re: gtx6970] #885249
12/23/10 10:13 AM
12/23/10 10:13 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Although I'm not 100% sure it's exactly OE . It's an MH harness and this is the best way to route it , where it fits.
Re: Cuda trunk wiring pictures [Re: gtx6970] #885250
12/23/10 12:50 PM
12/23/10 12:50 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
That's how my original harness routes also!
Re: Cuda trunk wiring pictures [Re: gtx6970] #885251
12/23/10 01:37 PM
12/23/10 01:37 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Does anyone have any pictures of how the "additional" ground wire routes for the rear side markers and tail lights?
Re: Cuda trunk wiring pictures [Re: jbc426] #885252
12/23/10 04:15 PM
12/23/10 04:15 PM
Snoopy Offline
Snoopy  Offline
70 Cuda
Re: Cuda trunk wiring pictures [Re: Snoopy] #885253
12/24/10 09:15 AM
12/24/10 09:15 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
70 Cuda
Wow, cool picture. Thanks, I've never seen that one before.
Re: Cuda trunk wiring pictures [Re: jbc426] #885254
01/06/11 03:51 PM
01/06/11 03:51 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Here is a shot of the wiring fwd of the wheel well. Is this correct to route around the gusset?
1972 Corvette
Re: Cuda trunk wiring pictures [Re: 19cuda73] #885255
01/06/11 04:13 PM
01/06/11 04:13 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Yah, but your missing a little bracket to retain the harness on the gusset.
Re: Cuda trunk wiring pictures [Re: 19cuda73] #885256
01/06/11 04:16 PM
01/06/11 04:16 PM
Snoopy Offline
Snoopy  Offline
Re: Cuda trunk wiring pictures [Re: Snoopy] #885257
01/06/11 04:31 PM
01/06/11 04:31 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Right on Thanks that looks like just one of those rubber coated retention straps screwed to the gusset
1972 Corvette
Re: Cuda trunk wiring pictures [Re: 19cuda73] #885258
01/06/11 10:58 PM
01/06/11 10:58 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
You have some great schematics? What manuals are these from? I have several chassis and body service manuals but no sketches like these. I believe these are the type of manuals I really need for my wiring installations.
1972 Corvette
Re: Cuda trunk wiring pictures [Re: 19cuda73] #885259
01/07/11 08:07 AM
01/07/11 08:07 AM
Snoopy Offline
Snoopy  Offline
They are factory assembly drawings. I managed to get a few from a popular Mopar site before Chrysler made them pull them. Faxon is suppose to offer a bound collection of the prints, but I haven't seen any progress. I would contact them and see when they plan to publish copies.
Faxon does offer a collection of engine manuals for 1969 cars.
MoPar factory assembly line manuals
Re: Cuda trunk wiring pictures [Re: Snoopy] #885260
01/07/11 11:43 AM
01/07/11 11:43 AM
cataclysm80 Offline
cataclysm80  Offline
Yes, hopefully Faxon will get those done, I'd love to have a full set. It's supposed to include diagrams that we haven't seen yet.
Thanks for posting those Snoopy. I especially like the ground wire diagram. Been awhile since I saw that one.
Happy New Year!
Tav
Re: Cuda trunk wiring pictures [Re: cataclysm80] #885261
01/30/11 12:45 AM
01/30/11 12:45 AM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Added the retention brkt and attached it to the gusset. Just used pull rivets. On the harness I have a trunk light which attaches to the tail light harness and then it hooks into the dome light.
1972 Corvette
