Cuda trunk wiring pictures
#885242
12/21/10 11:13 PM
12/21/10 11:13 PM
Posts: 1,300 Washington
19cuda73
Washington
Does anyone have pictures of the trunk wiring path for an e body? Tail light to over the wheel well housing.
1966 Charger 383 4 speed (Black with Red interior) 1973 Cuda 340 4 speed (Lemontwist) 1972 Corvette
Re: Cuda trunk wiring pictures
[Re: 19cuda73]
#885243
12/23/10 12:46 AM
12/23/10 12:46 AM
Posts: 916 Arizona
Chucklehead
Arizona
Only picture I could find from the 72 that shows.maybe it give you an idea of how it went over the wheel house.
Still Broke
[Re: Chucklehead]
#885245
12/23/10 12:54 AM
12/23/10 12:54 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
one more
Well your 72 isn't routed properly.... See the plastic loop taped to the harness? it should be attached to a clip on the left side up high on the trunk jamb..., the wires route over the wheelhouse the along the top edge of the trunk.. It drops down along the outside of the left tail light & passes across the bottom of the tail panel... Fact is if you look at the first picture you'll see the tab under the trunk jamb...
[Re: gtx6970]
#885249
12/23/10 10:13 AM
12/23/10 10:13 AM
Posts: 21,429 It's a dry heat
gtx6970
It's a dry heat
Although I'm not 100% sure it's exactly OE . It's an MH harness and this is the best way to route it , where it fits.
[Re: gtx6970]
#885250
12/23/10 12:50 PM
12/23/10 12:50 PM
Posts: 1,169 Richmond, VA
rayztoy
Richmond, VA
That's how my original harness routes also!
[Re: gtx6970]
#885251
12/23/10 01:37 PM
12/23/10 01:37 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Does anyone have any pictures of how the "additional" ground wire routes for the rear side markers and tail lights?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Snoopy]
#885253
12/24/10 09:15 AM
12/24/10 09:15 AM
jbc426
West Coast, USA
70 Cuda
Wow, cool picture. Thanks, I've never seen that one before.
[Re: jbc426]
#885254
01/06/11 03:51 PM
01/06/11 03:51 PM
19cuda73
Washington
Here is a shot of the wiring fwd of the wheel well. Is this correct to route around the gusset?
[Re: 19cuda73]
#885255
01/06/11 04:13 PM
01/06/11 04:13 PM
jbc426
West Coast, USA
Yah, but your missing a little bracket to retain the harness on the gusset.
[Re: Snoopy]
#885257
01/06/11 04:31 PM
01/06/11 04:31 PM
19cuda73
Washington
Right on Thanks that looks like just one of those rubber coated retention straps screwed to the gusset
[Re: 19cuda73]
#885258
01/06/11 10:58 PM
01/06/11 10:58 PM
19cuda73
Washington
You have some great schematics? What manuals are these from? I have several chassis and body service manuals but no sketches like these. I believe these are the type of manuals I really need for my wiring installations. Thanks
[Re: 19cuda73]
#885259
01/07/11 08:07 AM
01/07/11 08:07 AM
Posts: 8,850 Central Coast, Calif.
Snoopy
They are factory assembly drawings. I managed to get a few from a popular Mopar site before Chrysler made them pull them. Faxon is suppose to offer a bound collection of the prints, but I haven't seen any progress. I would contact them and see when they plan to publish copies. Faxon does offer a collection of engine manuals for 1969 cars. MoPar factory assembly line manuals
[Re: cataclysm80]
#885261
01/30/11 12:45 AM
01/30/11 12:45 AM
19cuda73
Washington
Added the retention brkt and attached it to the gusset. Just used pull rivets. On the harness I have a trunk light which attaches to the tail light harness and then it hooks into the dome light.
